odometer trick
Since i have joined this forum and posted my mods i got scared. A couple of people have had bad luck with their programmers, sorry about your luck i've had my superchips set on the HP setting for awhile its GOOD. OK the reason for this post is about the odometer trick and some DTC's that show up. They are as follows d027,d262,d073,d059 & d058. So im about to panic it just rolled over 36000 miles so now i want to puke. But i called a local FORD dealer and he said they were BS codes. Ford has come out with 3 updates for the mighty 6.0 and i only have the first. He says dont get the 2nd or 3rd cause you will loose about 15 to 20hp. The codes have to do with operating parameters but dont worry about them they wont hurt anything. Cause of no more warrenty i asked about my exhaust upgrade no problem he said, he also said programmers were not a problem either or air intake upgrades. Man i love Ford they have always worked with me and helped any way could. By the way the Motor and everything connected to it except the fuel system is covered to 100,000 miles weeewwww. Now i can breathe.
