Oil Bypass Questions - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 05-19-2010, 10:35 AM   #1 (permalink)
BryanDowdy's Avatar
Those of you with the amsoil bypass kit, where do you tap in to pull the oil from and then send the oil back? I do not want to do the filter/filler alum caps. I want to keep everything under the truck.
- 2006 F250, Studs, HG's, ID Tunes, EGR Delete, 4'' MBRP, Helper Bags, Glowshift Gauges
BryanDowdy is offline
Old 05-22-2010, 12:26 PM   #2 (permalink)
I connected off the oil pressure sender port on the top of the engine, and then returned to the plug in the driver side valve cover. Don't know of any supply and return locations on the lower part of the engine like the 7.3.
reoravec is offline
Old 05-22-2010, 04:36 PM   #3 (permalink)
paintingman's Avatar
You can have some one make you a banjo fitting and return the oil to you oil pan thru the drain plug like the FS2500 oil bypass system uses. But if you use your truck off road i would be afraid it could get snagged on a stump and pull the line off.
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
