Oil cooler? or EGR cooler - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 08-04-2009, 10:41 PM   #1 (permalink)
Ipolute's Avatar
alright im starting to notice some white smoke coming out of my exhaust... i have 145k miles and have been told it could be my EGR cooler... so im looking to replace my EGR cooler ,oil cooler, and i guess install a coolant filter... problem is i dont have a money tree in my back yard so im probably gonna have to do them one at a time or maybe two but not all threee... my question is what should i get first, second and third?... Thanks for the help
2005 F350 Lariat 4x4 6.0 Crew Cab
BFGoodrich Mud-Terrain KM2 35 x 12.5
Leveling kit
8k HIDs w/fog lights
Recon Side Markers(Smoked)
Recon Roof Lights(Smoked)
Harley Davidson Headlights
White L.E.D lights (Parking and Roof lights)
DieselSite Coolant Filter
3.5 Inch straight Exhuast.
Bully Dog Triple Dog w/outlook monitor
Cobra XRS R9G Radar Detector
Sinister EGR Cooler "fix"
.....At the Track..... http://www.youtube.com/watch?v=vMiWo6i5ZVA
Ipolute is offline
Old 08-05-2009, 12:14 PM   #2 (permalink)
Ipolute's Avatar
anyone?
Leveling kit
Ipolute is offline
Old 08-06-2009, 10:50 PM   #3 (permalink)
Bump!
Sonic Blue
2003 F250 Crew Cab 4X4 XLT
6.0/TorqShift Sport Package
10.5" Edge Lift-Dual Front Fox Res. Shocks/Single Rear-10" Rear Springs--SDHQ Billet Shock Clamps
18" X10" MKW #19 Wheels/38"X15.5" Toyo MT's
4.56 Gears, polished differential covers,
Full Face Billet Grill with 7"Blue Oval Lumilogo, Color Keyed Mirrors, Shaved and smoothed tailgate
Door Handles smoothed and keywholes filled in, fender emblems replaced with 10" Ford Oval, Billet Interior Items, LimoTint, Amp Research Steps,
Line-X Bedliner, MBRP Dual S.S. Turbo Back, Edge/Attitude, AFE ProGuard 7 Intake, Silver Stars, Huge Stereo System, Eclipse AVN 2454 Navigation, CD/DVD Player, JL 3-way comps, 6.5" coaxials, 4-Eclipse Aluminum 12"s, Zapco 4.0 & 9.0 Tons of Brown Bread Sound Deadening Material, Stinger wiring and fuse blocks, and 5 Farad Capacitor and Q Form kickpanels.
TBNR is offline
Old 08-07-2009, 10:21 PM   #4 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
Personally I would change the EGR cooler first, since that is the most likely cause of the white smoke, and try to back flush the oil cooler through the EGR cooler feed hose to make sure the oil cooler is not plugged up.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 08-08-2009, 10:02 AM   #5 (permalink)
InetDev's Avatar
Pull the EGR valve (two 8mm bolts, located in front of the top oil filter housing) and look inside. If it's wet, that's coolant and indicates EGR cooler failure. Look at the welds of the EGR cooler, if you see cracks, then it may indicate oil cooler failure since a blocked oil cooler will not pass coolant to the EGR cooler, which will overheat and get the cracks. If it's passing coolant, and the EGR cooler fails, you should see wet soot under the EGR valve.
Hope this helps.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
InetDev is offline
Old 08-08-2009, 10:20 AM   #6 (permalink)
Ipolute's Avatar
well i pulled the EGR valve and it was a little wet but nothing to really be worried about i guess... i just got my coolant filter and oil cooler so im going to put the filter on today and hopefully by tomorrow i can get the oil cooler in...how hard do you guys think that should be between 1-10
Leveling kit
Ipolute is offline
Old 08-08-2009, 10:28 AM   #7 (permalink)
InetDev's Avatar
The oil cooler is a pain, you need to remove a lot of items. Build or buy a topside creeper to help with the removing the turbo. Will never do lengthy engine work without one again, built mine for about $40 with some pressure treated lumber and it is hands down the best tool ever for working on these engines.
InetDev is offline
Old 08-10-2009, 10:46 PM   #8 (permalink)
EM2
EGR Cooler Failure
ANY AFTER MARKET EGR COOLER UPGRADES AVAILABLE FOR THE 05 6.0??????
EM2 is offline
Old 08-13-2009, 12:08 AM   #9 (permalink)
yes. do some searching around alot of options. delete kits (off road)wink, also alot of people just weld them shut.
06 4x4 cc amarillo loaded 20" wheels stock. sold to a lucky man,2000 f350 ex.cab propane 4inch s.s.exht,diablo 80hp chip .
http://www.photoserver.us/is.php?i=143695&img=redo2.jpg
ahurley is offline
Old 08-17-2009, 10:03 PM   #10 (permalink)
This thread should answer this question: egr cooler
TorqueMasterG is offline
