Oil Pressure Gauge Pickup location? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 01-26-2008, 07:45 PM   #1 (permalink)
Hi,
I'd like to know where/how you all are tapping in to install an aftermarket/real oil pressure gauge.
Also; where/how is the factory/ecm picking its signal up?
Thanks!
mblgjr is offline
Old 01-26-2008, 07:56 PM   #2 (permalink)
The oil temp sending unit is next to the oil filter towards the passenger side, mounting downwards. You can possibly make a T there, or just get a billet oil cap that has the fitting on it.
dfuser is offline
Old 01-27-2008, 12:36 PM   #3 (permalink)
IceMan89m's Avatar
My Photos: (12)
See your PM's
03 f-350 FX4 6.0 PS BullyDog Triple with Outlook, AEM Brute Force, Frantz Bypass, 8" Dick Cepek race series lift, 12"x16" Dick Cepek type 1 wheels, 36"x14.50x16 Parnelli Jones Dirt Grip Tires....
International Union of Operating Engineers
local 324....
AMA,District 14 & HOG member
IceMan89m is offline
Old 01-30-2008, 10:04 PM   #4 (permalink)
small square head plug at the drivers side rear of the block. It a port that "looks" at the main bearing . very accurate.
I have an oil temp gage plugged into the port at the oil filter housing, and used the block location for the pressure sender. it plugged right in no adaptor needed.
2000 F350 CC 4wd DRW, 4.10, Ultimate spray in bedliner, Hutches tank & prepump mods, H/X mod, Rhino Grillguard, Hella lights, DI Fuel Reg mods, Air Dog, Bob's 203 thermostat,80hp injectors, heater core bypass, FTVB & AIH plug. ZooDad mod,AIS filter, ISSPRO EV Oil,Water,& Tranny temp,Pyro,Oil pressure,Boost gauges, non EBV pedestal & Turbo outlet, Garrett BB turbo, MBRP 4" duals, PML trans pan,front & rear diff covers, more to come.
horses2 is offline
Old 02-01-2008, 09:35 AM   #5 (permalink)
601HP's Avatar
This is the 6.0L engine forum.
mblgjr and horses2; are you guys refering to the same engines? I can't determine which engine mblgjr has. Looks like horses2 has a 7.3L.
David
2004 F350 Lariat, CC, LWB, 4x4, Dually, 6.0L w/ TorqShift, 4.10 LS, Dark Charcoal Gray, Permatech sprayed liner, A-pillar pod with 3 Isspro gauges, windshield-mount gauge pod with 3 more Isspro gauges, AIC, Jason cap, and PIAA fog lamps, mounted as aux. back-up lights. Billet badges. Alpine radio, a bunch of JL Audio and Sirius stuff.
<font color="blue">Photos</font>
601HP is offline
Similar Threads
Oil pump pickup location CAP Power Strokes 1994-1997 General 4 09-10-2007 11:49 PM
Oil pressure gauge sender location? markhjgrant Upgrades and Aftermarket - 6.0L Engine 9 05-04-2006 11:09 PM
Oil pressure/ oil temp sending unit location COBRAJET Upgrades and Aftermarket - 6.0L Engine 9 08-22-2004 10:17 PM
V-10 Oil pressure gauge line location ZeroTolerance 1999-2007 Gas Engines 4 09-22-2002 02:01 AM
Oil pressure sensor location Stan Wright 1999-2007 Gas Engines 0 08-25-2000 06:17 PM
