oil pressure and oil temp - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 02-05-2008, 03:14 AM   #1 (permalink)
Firematt71's Avatar
i wanna put in both a oil pressure AND temp gauge....can i only use my oil filter cap for one of these gauges, or can i hook both of them up there???? and if so what is the best setup as far as what connections to use thx matt
2003 F350 4X4 Long bed Charcoal Crewcab 6.0l Diesel, built 01/03, Sports Pkg, SCT XCal, Boost Trany EGT Pilar gauges, Airaid Cold air intake, MBRP 4'' Turbo Back Exhaust with 5'' Tip, Bed Line-X, Smoked tailights, Ford Idle Controller, Donahoe 10.5 Lift, Toyo 38's, Mag-Hytec Tranny + Front and rear diff covers, Banks Intercooler, Dieselsite Coolant Filter, and more to come.
Firematt71 is offline
Old 02-05-2008, 06:56 AM   #2 (permalink)
601HP's Avatar
I did both from that location. It's best to use an aftermarket billet cap. The factory cap is not really adequate to drill and tap. I already did that too. Look in my Photos section.
David
2004 F350 Lariat, CC, LWB, 4x4, Dually, 6.0L w/ TorqShift, 4.10 LS, Dark Charcoal Gray, Permatech sprayed liner, A-pillar pod with 3 Isspro gauges, windshield-mount gauge pod with 3 more Isspro gauges, AIC, Jason cap, and PIAA fog lamps, mounted as aux. back-up lights. Billet badges. Alpine radio, a bunch of JL Audio and Sirius stuff.
<font color="blue">Photos</font>
601HP is offline
Old 02-05-2008, 10:09 AM   #3 (permalink)
I did the same; billet cap with both pressure and temp sensors hooked up. Works well for me. I think I got the amsoil cap as I needed it quickly and they had it in stock at the time. The sensors that came with the gauges I had put in (SPA Techniques) have disconnects in the wiring down by the sensors so it's still easy to take the cap off for filter changes.
05 F350 CC LWB SRW
Immortl is offline
Old 02-05-2008, 01:38 PM   #4 (permalink)
Firematt71's Avatar
David
thx for the pics...makes it easier than trying to visualize....how hard are oil filter changes with that setup
Old 02-06-2008, 09:04 AM   #5 (permalink)
601HP's Avatar
Firematt71:
On the one side of the 'T', I unscrew the braided oil pressure line where it connects to the 'T'. The other side of the 'T' is for the oil pressure sending unit, which has a plastic quick-connect about 6" away from the 'T'.
Removal of those two items takes an extra 2 minutes to accomplish prior to unscrewing the billet cap. I leave the 'T' undisturbed, and use an adjustable wrench to remove the cap.
David
601HP is offline
Old 08-06-2008, 12:04 PM   #6 (permalink)
I know this is an old thread, but I just found this forum and have been trying to figure out how to run an oil temp sensor. Where do I get the tees that hook up to the top of the oil filter cap? Does this location give accurate temps?
new2deisel is offline
