Onetondually - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 09-22-2008, 06:16 PM   #1 (permalink)
Onetondually
Is It Recomended To Use Head Studs If You Are Running A Chip And What Is The Best Chip To Get AND Should The Exhaust Be Re Done
ONETONDUALLY is offline
Old 09-22-2008, 06:45 PM   #2 (permalink)
Most here would recommend a tuner over a "chip".
IF I were going to do it, 1st a good set of gauges (EGT, Trans Temp, Fuel pressure), next a SCT (pick your tune), then head studs & a trans rebuild. 4" cat back if you're towing heavy or at altitude.
But, for me, my stock truck is working fine & I have other places I'd spend that t+/-$4.5k.
OMC
OMCUSNR is offline
