problems with oil bypass/coolant filter clearance - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-16-2011, 05:07 PM Thread Starter
got around to working on truck and when trying to install nuc oil bypass and sinister coolant kit they run into each other. Anyone have pics of mounting coolant kit in different location?
CoyoteCody is offline
post #2 of 7 (permalink) Old 11-16-2011, 06:38 PM
07PstroKe's Avatar
Send a message via Yahoo to 07PstroKe
Hey Cody, you can mount any filter anywhere. I know guys who have mounted the coolant filter behind the front bumper and frame mount they're oil bypass. Dieselsite sells a frame mount for the coolant filter. Considering you already have sinister (such as I) I suggest mounting it to your frame rail, getting some earls fittings and braided hose and running line to and from your bypass kit. Do you have the resources to fabricate your own mounting bracket?
By doing this, access will not be an issue and your filter changes will be cake.
Larry M.
2007 F-350 6.0 PSD MURDERED
6" Procomp stg II w/37" Toyo M/T's on rockstars
Edge Juice
Stacked 7" straight cut
Pioneer D2 Nav
Sinister Coolant Filtration
Amsoil oil bypass
Blue spring "update"
BD Power hose/clamp kit
CFM+ Intake
6.4 Banjo bolt upgrade
07PstroKe is offline
post #3 of 7 (permalink) Old 11-17-2011, 01:14 AM
SmokerSteve's Avatar
I have my oil bypass in the bumper. My coolant filter in the engine bay nest toe the battery and hot side boost tube.
2006 F-350 79,000
FICM Testing Videos
How to get more than 8-7 Quarts Transmission FLush
Stock Truck, DTC, California, and SMOG safe EGR System Mod
SmokerSteve is offline
post #4 of 7 (permalink) Old 11-17-2011, 02:25 AM Thread Starter
yes it sucks as I was trying to keep everything simple and bolt on so I didnt feel like it was another race car or buggy. Cost 3 times as much for bolt on and hurts your feeling when it doesnt work. Not sure if I'm just gonna extend the oil bypass bracket or mount in remote location. If I have the fittings and hose in shop prob remote and if not I'll throw something on the mill and make it look nice as is. This is like a big block ford in a falcon with the wells still in it. Hard to change plugs but worth it in the end!
post #5 of 7 (permalink) Old 11-18-2011, 04:59 PM
paintingman's Avatar
Here is another way
6.0 oil bypass filtration system and parts 6.0 billet aluminum filter cap airdog II - Diesel Oil bypass filtration & Coolant kits Ford Powerstroke 6.0 Chevy 6.6 Dodge 5.9 Parts Filters Aluminum oil filter caps Powerstroke Crankcase vent
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #6 of 7 (permalink) Old 11-18-2011, 06:20 PM
07PstroKe's Avatar
The kit that paintingman posted is a nice kit, a bit too much bling for me. I installed this kit on two trucks. Although confined, there was adequate space to pull and reinstall the filters. I'm just not a huge fan of a congested engine bay, but installation is simple with this kit.
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
post #7 of 7 (permalink) Old 11-19-2011, 11:27 AM Thread Starter
yes should have went that way. I got it but had to do a bunch of moving and mods. Filters are just about straight up and down which I like
