Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 12-07-2005, 09:00 AM   #1 (permalink)
Propane
Looking for some feedback on the various propane injection systems on the market. I'm not looking to drag race the 1/4 mile or interested in huge power gains. I'm lookin g at this from a fuel efficency prospective and low-end power increase. I'm also interested in any long term effects on the engine.
Current rig is a 05 F350 6.0L w/Manual trans. My summer time milage is in the ball park of 20 to 23 and winter is around 19. I'm looking for more response from the bottom end with out going to extremes.
2005 F350 4x4,Supercab 6.0 w/manual trans, tow package Stock.
DRWB is offline
Old 12-07-2005, 09:27 AM   #2 (permalink)
Re: Propane
I have our propane kit and it works real well on my 6.0L. Nice power increase without a tuner or chip and my mileage picked up at least 2 mpg.
Tadd
Elite Diesel Custom Tuning www.elitedieseleng.com
tadd@elite-diesel.com
1-866-631-8518
Elite Diesel SCT Tuning for 6.0 and 7.3's with Cylinder Pressure Adjusted tunes, Programmers or 6-position chips, Custom 6.0 Injectors, 2 Stages of 6.0L Fuel Systems, H-11 Head Studs, Fire Ring Kits, Single and Compound Turbos for the 6.0L, Engine Internals
04 F350 XLT SPORT CC DRW
Elite Diesel SCT Tuner,AFE Stage 2, 345cc Injectors, 6" Stacks, S400 turbo. 701hp on #2
Look in the september issue of Diesel Power Mag.
Ford Senior Master Technician
TaddL is offline
Old 12-07-2005, 09:34 AM   #3 (permalink)
Re: Propane
There's Powershot 2000 and there's the vaporizer systems like MSD, ATS, Bullydog, etc. If you're looking for efficiency, safety and legality over long term use consider the vaporizer systems.
'99 PSD, CC, DRW,
'97 PSD, Reg Cab, 4R100, intercooler, Superduty turbo, Stage I's
Tinscout is offline
Old 12-07-2005, 05:01 PM   #4 (permalink)
Re: Propane
I have a question aboutyour fuel mileage? How is it so high? Mine averages between 13 to 14.9 MPGS. I barely have 14500 miles on it and it is a brand new 2005 F250 PSD
chuco is offline
Old 12-12-2005, 08:35 AM   #5 (permalink)
Re: Propane
I have talked to a lot of folks with the 5 speed auto that get about the same milage as your getting.
Mine, I drive it like a truck. Not in a hurry run the RPMs to 1900 or so and shift. Stay under 70 MPH. Towing 6-9K trailers I get around 14 MPG. Drive the same way. I have a Hi flow filter (K&N) but other than that it's just smooth driving. The more the turbo spools up the more fuel you use.
Never been back to the dealer to re-flash my computer and had no problems.
Good truck.
DRWB is offline
Old 12-20-2005, 12:12 AM   #6 (permalink)
Re: Propane
I get 18.6, but mines a 2WD CC..
Look at the MSDS kits or the PS2000, I would stay away from the Bully Dog kit.
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
Mach1 is offline
Old 12-20-2005, 09:06 AM   #7 (permalink)
Re: Propane
DRWB,
Check the MSD systems out, they have all the safety features combined that the other systems have some of but not all of. It has it's own ECU that allows you to down load to a lap top and make varoius control changes to make it operate how you want it to vs a pre set operation etc. It's not the cheapest but we think it's the best and safest available. If you have any questiosn just call.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
Mark Craig is offline
Old 12-20-2005, 03:04 PM   #8 (permalink)
Re: Propane
does it leave an ecm trail,the msd kit?
2003 X Limited 4WD 6.0,auto,55k mi. I'd buy another if FORD still made them.
1993 F150 4WD,5.8,auto,33s,315k mi.Never been stuck.YET!
New ride 1995 FRTLNR FLD120 Reman DD12.7 470hp,13spd,3.08 rears.Yeah I know,all the DD bashing I've done and I go and buy one.With the reman in it for $14,750 my mechanic said if I didn't buyit he would.
4 SALE 1993 FRTLNR coe N14 460hp,13spd,single axle,all aluminum wheels.
claytonr is offline
Old 12-21-2005, 11:07 AM   #9 (permalink)
Re: Propane
truckdriver,
Not that I have even heard as it's ECM is totally seperate one from the Ford one.
Mark @ DPPI
Old 12-22-2005, 12:14 AM   #10 (permalink)
Re: Propane
mikey really likes his ps2000 kit...
2004 F250 fx4 cc sb lariat 6.0, gray/black, everything, 6" edge & 3" hangers, rear 5" deavers & 3" blocks, 5150s front, 5100s rear 39.5" irok radials, 16x10 black helo maxx, 4.88s, warn premium hubs, fabtech adj. trac bar, rancho stabilizer, SCT "bustin that ass" tune by PDP, powershot propane kit, 4" stainless turbo back straight pipe w/ 6" HOG tip, airaid intake, APC projectors, APC corners, rebased philips 4300k HIDs with denso ballasts, donahoe lightbar, 3 hella 4000s, 2 pairs of KC backup lights, train horn, 200psi vaiar 380c & 6 gallon tank, kenwood 915dvd head unit with 4100 nav, sirius satelite radio, kenwood music keg, rockford 1051x, rockford bd1000.1, mb quart qsd216 in front doors, mb quart qsd213 in rear panels, 2 10" kicker L7s , RG gun rack, husky floormats, rhino liner, uws toolbox, UWS 100g aux. L tank, 14" solid stock drop hitch, more comin... MY TRUCK
1985 nissan on 33" boggers, the real mud monster...
mikeym is offline
