Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 11-15-2005, 06:14 AM   #1 (permalink)
Quad module.............Best location to mount inside cab?
I have the 30-60-110 Quad module, and I am trying to find the best place to mount the box so I can see the LED light. For those who have this module,.......where do you have it mounted?
2004 F-350 CC XLT, 6.0L PSD, 6spd, Dark Shadow Grey, 6-disc CD changer, Turnover gooseneck hitch, Quadzilla Xzillaraider, Husky Mudguards, Texas Ranger CB w/ Wilson Antenna
2003 Exiss CX-400 Aluminum Horse Trailer
2000 F-250 SC 4X4, 305/70/16 Maxxis Mudders, 6spd., white/silver, Alpine CD, rear air bags,. (SOLD)
www.leblancquarterhorses.com
LSUalum is offline
Old 11-15-2005, 07:29 AM   #2 (permalink)
My Photos: (22)
Send a message via ICQ to rgdillon
Re: Quad module.............Best location to mount inside cab?
Under the dash - I don't really need to see the LED unless there was a problem.
Ron
<font color="blue">NOVAPS Member</font>
<font color="blue">NOVAPS - Northern Virginia Power Strokes - Interested?</font> <font color="blue">Visit the</font><font color="red"> NOVAPS</font><font color="blue"> WebSite.</font>
<font color="blue"></font>
<font color="green">2004 F-350 King Ranch CC SRW - HP Green -</font> AIC mod, Di–Pricol Gauges, Silverline, BrakeSmart and a few other things . .
<font color="green"> King Ranch Pictures </font>
<font color="green">Strobe Video</font>
OLD -<font color="red">2001 F350 Lariat PSD 4x4 Crew/Dually</font> - AIC, AIS, Di–Pricol Gauges, AMSOIL Dual Bypass Remote, SunCoast Transmission, Tru-Cool Max, Wicked Wheel, TS Performance 75/75/125 Flip, SilverLine SS Dual Exhaust and some other stuff.
rgdillon is offline
Old 11-15-2005, 08:43 AM   #3 (permalink)
Yeah,..that is where I have it mounted right now. Actually, it is right next to the fuse box. But, it would be nice to see the LED for a quick reference to see what level you are in, and also to see if everything it working properly on startup ( the module check sequence).
LSUalum is offline
Old 11-15-2005, 11:52 AM   #4 (permalink)
I have mine under dash but u can see the light glancing down under the steering wheel from that small space that is there. I have only used settings 30 and 60 and my egt runs alot cooler and gas milage is better 1 to 2 mpg depending on how I drive in town and highway is averaging 21-22 mpg up from about 18 mpg. With the power it has I dont need to use the highest setting.
2007 PSD 4x4 F-250 Lariat Outlaw 6" Fabtech lift
2005 PSD 4x4 Ex Limited
05F350Boy is offline
Old 11-15-2005, 01:48 PM   #5 (permalink)
My Photos: (30)
Get the new lighted switch and you won't have to worry about the built in LED.
wifes truck 02' Excursion Limited PSD 4X4 -Quadzilla Xzillaraider module, Transgo shift kit.
06' VW Jetta TDI
06' F-750 CAT C-7 and CAT CX28 automatic transmission
CarterKraft is offline
Old 11-15-2005, 02:05 PM   #6 (permalink)
Thanks.............I didn't realize there was a lighted switch for these modules. I'm going to try and relocated it first, and if that doesn't work, I will call Quad and get the lighted switch. Anyone know the price for this switch?
LSUalum is offline
Old 11-15-2005, 06:56 PM   #7 (permalink)
My Photos: (22)
He told me months ago he was coming out with a new switch - have never seen any mention of it on the website - guess I'll have to call also.
Ron
rgdillon is offline
Old 11-16-2005, 08:02 AM   #8 (permalink)
My Photos: (30)
Sorry, I have a habit of releasing info.
06' VW Jetta TDI
Old 11-16-2005, 12:01 PM   #9 (permalink)
My Photos: (22)
[img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img]
Actually Quad sent me an email several months ago and said he was working on a different switch. My first switch went bad - (truck would shut off when switching) - so I have been waiting for the new one to come out.
Ron
rgdillon is offline
Old 11-16-2005, 10:26 PM   #10 (permalink)
My Photos: (30)
Well I have seen them, and I might have a few but hopefully they are being shipped. With work the way it is now I don't have as much time to play anymore.
06' VW Jetta TDI
Old 11-17-2005, 10:11 AM   #11 (permalink)
Quad emailed me yesterday and said they will probably have the new switches available after the first of the year.
LSUalum is offline
Old 11-17-2005, 05:58 PM   #12 (permalink)
Let me clear this up so it is easy to understand.
The new switches are out and are being shipped with current product. The LED portion is not available at this time. The company that builds the LED lense and the cup has us on backorder.
The LED portion will be an additional cost, but not much.
The LED will only display the power level you are in. It will not show the startup sequence or the warm up sequence. That is embedded into the PCB.
The new switch is very distinguished from the old switch so it will be easy to tell if you have the new or old switch.
The new switch is mounted on a small pcb. The first versions were on a green board and the current version is on a black board. You will have a cable with a small flat connector on one end that goes to the board and the other end will have a small square 4 pin connector. The flat connector goes to the connector on the pcb.
On the pcb there is an 8 pin connector. Your switch should come connected from us. If you disconnect it there should be adequate markings on the pcb as to which terminals you need to connect the switch part to. The other end of the terminals is used for the LED. When the LEDs ship you will be able to add it to the new switch if you want to.
Hope that helps.
Quad
QuadBoenker is offline
Old 11-17-2005, 07:09 PM   #13 (permalink)
My Photos: (22)
Any chance of getting a picture of it before I try to order one?
Thanks,
Ron
rgdillon is offline
Old 11-18-2005, 06:49 PM   #14 (permalink)
Would definitely like to see a picture of this, also.
LSUalum is offline
