Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Do Aftermarket "chips" void the warranty on a new 6.0 diesel, simple question? I think they do. But will stand aside if I am wrong. The reason I ask is that many are choosing to use them, and with some of the problems with the 6.0 I would hate to see a guy left out to hang on an unrelated problem, i.e. injector failure or rear main leak, and let Ford hang it all on the "chip". If you put one in, is that it, can they say regardless of the engine failure, you "chipped" it see ya later on a warranty claim............Hig............. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
The Ford dealers don't even seem to have a consensus on this one. Some of the dealers down here don't have a problem with chips and others do. Same with suspension lifts from what I've read here, although none down here have a problem with them.
I agree with you that I wouldn't chip mine until all the problems are ironed out of the 6.0L. Once that happens (and I seem to be in the minority in saying that I think it will happen and fairly soon), I would chip mine if I felt there was some benefit other than MORE POWER. As for me, the 6.0L has more than enough power for what I use it for.
As for those that have had problems and are down on Ford for it, we all knew when we bought the thing it was a new product and 1st year problems have been the rule rather than the exception for every manufacturer. I can't see getting irritated with Ford unless the problems fail to be corrected within the first year.
Cheers
<font color="blue"> 2003 F-250 XLT Crew Cab FX4 </font>
6.0L/Auto, 3.73 LS, SOF FX4, Oxford White/Gray Interior, LWB, Camper Pkg, Towing Pkg, 6 CD Changer, Power Driver & Passenger Seat, Adj. Gas & Break Pedals, Rhino Lining, Hand Painted Pin Striping, One Piece Alum. Billet Grill, 4-1/2" Edge Lift, Billet Adj. Pan-Rod Bar, Fox Steering Stabilizer, AE 589 16x8 Wheels, BFG AT/TA 315/75R16's, AFE Pro-Guard Air Fliter, N-Fab Nerf Bars, B&B Stainless Turbo Back Exhaust, Lunar Guages
I am trying to educate myself abou them. Quad, Edge and TS. I will probably chip the truck at some time after everything is stable with em. To play it safe- I am making criteria one that is easy to install/remove and one that leaves no traces behind computer or otherwise.
Maybe the "chip" guys could step up and say, " If you have a warranty claim denied, due to the installation of our chip, we will reimburse you for your repairs"............Not gonna happen, cause they know the truth.............Hig................... [img]/ubbthreads/images/graemlins/eek.gif[/img]
yep, refer you to it, but not help you stand up with it. I guess I can understand that it would be impossible to give legal support to every guy who gets his warranty pulled.
I have nothing against chips, they just have to be used wisely. We have been using a SCMT on our 7.3L for quite awhile now and its great so I cant say I'll never use one on my 6.0, but Im definately waiting until ALL the bugs are ironed out and also until I have a good 20K or more on the motor.
2004 CrewCab 2500HD 4x4 D/A
2005 F-350 CC DRW! Tan over Black
~Hope the 6.0 is better now! [img]/ubbthreads/images/graemlins/wink.gif[/img]
Somewhere (I can't find it tonite, but I know it was on the internet) I read a TSB from Ford on the use of aftermarket chips. It flat out said there was no warranty on a chipped engine, period. I'll do somemore searching tomorrow and see if I can find it.
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
Hello Hig...I was told by my dealer that if I chose to put a chip in, they wouldn't have a problem as long as I got it serviced by them. But....if I was towing a trailer 200 miles away and had a tranny problem, or anything else that failed, I would most likely be SOL. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Also, when I ordered my new 2004 F-350, I asked about getting a remote starter put in it as I was going to leave mine in the old truck, instead of swapping things around. The dealer told me that Ford has made it clear to all dealerships (Canada anyway) that they will not install remote starters, or alarms, in any Superduty due to the fact that they have had to many starter failures in the past. But he did say I could get one installed after by another company.
I myself had a remote starter installed within days of taking ownership of my 2003 F-350. And I have started this truck countless times everyday, (I only use the remote in the morning) and I have not had a problem at all. I haven't read of any problems here @ TDS either.
What a crock!!! [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I won't be chipping mine untill all the bugs are worked out. I have no intention of voiding the warranty on an engine that costs this much......
__________________ Stripping her Down to be Sold <font color="blue">03 Black over AZ Beige CC LWB FX4 DRW Lariat</font>
DPPI T304 Turbo Back Exhaust*Edge Mini Spring Pack*New A/T Revo's*Hellwig Front & Rear Anti Sway Bars*Bilstein Shocks*VelvetRide Shackles*ProFlaps*Line-X'd*HarleyPedals*Chrome Tow Hooks*DashMat*VentShades*SilverStars
TubularSteps w/Aux Mkr Lights*LED Cup Holders*24" Silicone's*BrownBread*Wilson 5K Hard Mount CB & Cell Antenna*Rancho 5406 Stabilizer*Rear Eclipse 6x9's*Juice with Attitude <font color="blue">Volvo VNL770</font>
500 HP Series 60 Detroit*AutoShift*231" WB w/Air Ride Cab*Heated AR Seats*Heated Power Mirrors*Power Windows & Locks*Garmin 2610*Alpine In Dash XM Stereo w/Dual DVD Changers*Dual Bunks w/Work Station*Fridge/Freezer Combo
Microwave*15" LCD TV w/DVD in Sleeper*BrakeSmart*Backup Cameras*Pressure Pro Tire Pressure Monitoring System
Crapper
It's up to your particular dealer. If you have a good dealer, there shouldn't be any problem. Mine will fix my truck without question.
If you go out and decide to install that powerFOOL thing, and propane, add in some stacked chips and blow her up on the drag strip, I guarantee a Ford field rep Will come over to your dealer and investigate. He will look for clues to try and see if aftermarket performance stuff was to blame. Then you are guaranteed to be holding the bag.
Motto:
If you chip and start running 450+ HP, you better respect it. Run a pre turbo Pyro and keep it under 1,250 degrees.
Big HP and heavy weight can break parts, be a little easier on your tranny and change your oil every 3,000 miles to get rid of the extra soot. If you use some common sense, there will never be a problem resulting from a module.
Well, the official word from Ford is in bold print on Page 2 of your 6.0 Diesel Supplement booklet.
"Some aftermarket products may cause severe engine and/or transmission damage. There are various manufacturers offering devices to increase turbocharger boost, exhaust brakes to increase stopping/hauling capacity or other such devices to increase the power/torque of the Power Stroke engine. Many owners' past experience with these products has been very poor. Severe powertrain damage may result from the use of these aftermarket products which will not be covered by the Ford warranty."
If you have a mod-friendly dealer, more power to you (hey, I made a pun!) but it doesn't look like you have much of a leg to stand on if Ford questions it. Maybe they couldn't deny a water pump warranty claim, but the tranismission, turbo, injectors, valvetrain, etc. could all plausibly be affected by these power boxes.
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
I was reading a post by an Administrator of another site and he stated there is no such thing as a "chip" currently available for the 6.0. He stated the products now available are more akin to the 7.3 "edgebox". He stated a chip actally programs onto the vehicles ROM and entirely changes programming, while the products now available only change the "fuel curve", he said no one has come out with a true "chip" yet............Over my head,........... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Well there is nowhere to plug a chip in, with the 6.0 PCM, so that is correct, no chip. So far the strategy seems to be to diddle with various engine control signals outside the PCM, with an external plug in box, so nobody is even doing the same thing a chip did, i.e. changing how the program itself in the PCM operates.
Duncan
Hig
When I bought my truck the dealer sales and service folks that made a point during the pedelivery walk through to mention that if they found the truck "Chipped" or there were signs of it being chipped (the 6.0 evidently has a way of telling them)(Doc confirmed it) the Warranty on the drive train WOULD BE VOIDED (this could include everything too). It was not their call but that Ford was telling them to do it (no matter what)
Now think about this... your dealer may be mod friendly and then you go on vacation and have a problem. That dealer may not be mod friendly and report the finding voiding the warranty.
Personally I have no problem with safe mods...I just cant afford to pay to play. I do have a problem when someone does do the chip/mod, gets in trouble, then wines he is being treated unfairly by Ford when his real beef should be the chip folks for leading him astray. They then leave them hanging only saying that the M&M act should cover him.
Just my 02...I'm sure this will light some fires. Flame suit on [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/bleh.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img]
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
That is what I read and was referring to last night. Duncan, you probably saved me a bunch of time there!!
