Questions about EGR delete - Diesel Forum - TheDieselStop.com
post #1 of 22 (permalink) Old 03-10-2011, 06:57 PM Thread Starter
dirtystroke's Avatar
I just installed a Sinister EGR delete kit on my '05 6.0 powerstroke. After fighting with the clamp on the y-pipe and breaking it, i got a new clamp and finally finished the install (a day later). I drove the truck and could not get it to boost more than 22 psi..... NO MATTER WHAT. The truck was boosting around 32 to 34 before the egr delete. So I came here read some forums and concluded that i had a boost leak. I checked the hose from the intake to the map sensor and no leaks. I then pulled the boots off the pipe from the turbo to intercooler and cleaned all the oil off. Now it will boost around 27 psi when you floor it, stay there until about 80 mph when the torque converter locks and FINALLY go up to 32 psi. Just wondering if lower boost is a side effect of the egr delete???? Sorry for the long post just don't under stand why it takes so long to get full boost.
'05 F250 CrewCab FX4 Lariat 6.0 PSD, Green filter, Zoodad mod, SCT Livewire, Vivian's Looney Tune, 4 inch turbo back straight pipe, Sinister EGR delete, Blue Spring upgrade, Upgraded STC fitting, CAT ELC coolant, level kit, 5% limo tint, 35 Toyos and 20s, Recon smoked cab and mirror lights, Recon fire/ice LED stick under tailgate, fog light mod, Camlocker toolbox
'04 TJ Rubicon 4.0L, Auto, Rusty's 5.5 suspension, chromoly axles f/r, on-board air system, Go-there-engineering bumpers, 35s, Tom Woods driveshafts, etc.
dirtystroke is offline
post #2 of 22 (permalink) Old 03-11-2011, 12:17 PM
KingKong's Avatar
My Photos: (11)
I may be wrong but 34 is too high of boost # unless you have somekind of program I have been told a exhaust without a cat will have a little lower boost # also do you still have the egr value pluged in?
07 F-250 6.0 L CC XLT 4x4 Red Addons: ARE Cover, WheelSkin Cover, PML Rear axle Cover, Dieselsite Coolant Filter, C-better Mirrors,Gauges Isspro Fuel press. Trans Temp. EGT gauge. Gauges from Diesel Manor. Edge Insight CS (For EOT & ECT)
04 F-250 6.0 L CC XLT 4x4 White Buy Back
...... 06 Jayco Travel Trailer 32'
KingKong is offline
post #3 of 22 (permalink) Old 03-11-2011, 04:36 PM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
you will have less boost with a egr delete. to much boost on a stock turbo makes for early retirement
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
post #4 of 22 (permalink) Old 03-11-2011, 05:45 PM Thread Starter
I do have a superchips program. Just something to hold me over until i get some SCT tunes. Yes i have the EGR valve still in place and plugged in. No check engine light on. Thanks for the replys!
post #5 of 22 (permalink) Old 03-12-2011, 07:09 PM
paintingman's Avatar
When running with a tuner you want to keep you boost down and definitely with out head studs
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
post #6 of 22 (permalink) Old 03-14-2011, 02:45 PM
Scott@Superchips's Avatar
We offer a Racing tuner that offers EGR and DPF delete options along with additional offroad tuning levels for more power Link: Announcing the all new Ford Diesel Racing tuner from Superchips Racing!!
You can also call customer service and ask about our trade up program to save some $$ on the upgrade.
Let me know if you have any questions.
Scott
Scott@Superchips is offline
post #7 of 22 (permalink) Old 03-15-2011, 07:53 AM
As far as I know the 6.0 never incorporated a dpf filter. Is the product your talking about scott for the 6.0 or for the 6.4?
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
post #8 of 22 (permalink) Old 03-15-2011, 08:12 AM
Sorry for the confusion, the DPF feature applies to the 6.4L and 6.7L once completed. The EGR feature is available to all applicable engines with EGR present.
Scott
post #9 of 22 (permalink) Old 03-16-2011, 08:59 AM
caissiel's Avatar
Since I deleted the EGR cooler I find that the truck has less power when cold. This is caused by the egr being out of the loop and the turbo vanes are shut for EGR bypass flow. Then the boost will be low if the flow through the EGR cooler is not there. It gets back to normal once the coolant temperature is above 170F.
I would not have above 23PSI at any time on a stock truck. Its build for that and no more for sure with all the HG problems owners have had
2005 Ford SD F250, 6.0L Diesel, Extended Cab, 4 x 4, 6 Speed, 2 Alternators, 2008 Mirrors, 10,000GVW, Max Energy by Hypertech, ScangaugeII for available 60 XGauges and MPG. 20MPG and 12.6 MPG Towing a 15500Lbs 38ft RV 5th Wheel.
caissiel is offline
post #10 of 22 (permalink) Old 03-16-2011, 04:50 PM
mwilbur516's Avatar
I never boost more than 25lbs. Even on my SCT with the Looney tune (making insane power). BTW, Keep saving for the SCT. The superchips stuff is not custom tunable and won't reprogram your tranny, thus causing very expensive problems. The SCT will offer custom tunes that will keep you safe (or as safe as you can be) without studs.
06 F250 XL, FX4, Upfitters, TBC, 15% window tint, 3.73's, Muffler delete, Cat delete, Fumoto valve, High idle mod, Zoodad mod, Harpoon mod, CCV mod, ARP studs, SCT Livewire w/ Looney Wild DD Tune, Dieselsite.com coolant filter, Glow Shift Fuel Pressure Gauge, Ford Blue spring upgrade, 6.4l Banjo Bolts, Upgraded turbo boots, Upgraded HFCM drain plug, Quick Tricks 58 volt FICM, S&B CAI, Monitoring EOT, ECT, EGT, IAT, Voltage and RPM
Horsepower is like a gun; You may not always need it, but it's nice to know its there
mwilbur516 is offline
post #11 of 22 (permalink) Old 03-16-2011, 10:30 PM Thread Starter
Thanks for all the replies guys! After driving the truck for a week now, I've noticed what caissiel said about the truck getting its power back after it warms up. Its definitely running smoother and spools alot faster than before the delete And mwilbur516 I'm anxiously waiting to get an SCT, just wanted to get the egr crap off first.
post #12 of 22 (permalink) Old 03-17-2011, 08:55 AM
can you give me some info on who did your SCT tunes? my truck is a 2007 with the delete, 4" turbo back, headstuds, etc and I am on my 6th Innovative tune and I do not care for them. the converter don't lock soon enough and slow starts (never getting over 10 lbs of boost) and the truck goes to 2700-3000 rpms before it shifts. that to me seems like just a waste of fuel.
2004 Competition Orange Cobra (605 rwhp @ 17psi)
2007 F-250 DSG on 20"s
2009 VW Routan (wifey's)
Boost_Freak is offline
post #13 of 22 (permalink) Old 03-17-2011, 12:30 PM
Please detail what extensive problems you are referring to? We wouldn't have released the product if that were true.
Scott
post #14 of 22 (permalink) Old 03-17-2011, 08:33 PM
mwilbur516's Avatar
The same problems that all " one size fits all " tuners are known for. The biggest of which is smoking the tranny because your tuners DO NOT reprogram for the new power band. Also, head gasket failure. Although any tuner will blow head gaskets if put on the highest power level and run like a dragster without studs, the non-custom tunable tuners are much worse about this. Its mostly due to the fact that there are hundreds of different strategies on these trucks and each one runs different. Your tuners make minimal changes to make a little more power without taking into consideration any specifics of each vehicle. With the SCT or Edge Gryphon, you actually talk to someone and explain what you have modded (Studs, EGR delete, Turbo, Injectors, Intake, etc.) and he/she will build a tune/s made specifically for your vehicle and strategy. The transmission is also adjusted in these tunes to account for the dramatic change in power. The SCT and Gryphon units also rewrite your computer while saving a copy of your stock file so you can go back to a stock setting without leaving a trace of the tuner. Oh and here are a few other things to take into account; tire size, gear changes, more smoke, less smoke, shift firmness, line pressure, boost, cylinder pressure, torque converter settings, WOT shift points, engine braking, along with countless other parameters can be adjusted by a tune writer of the customers choice to achieve the absolute perfect driving experience. Not to mention the incredible power gains achieved by custom tuners while still being able to keep a specific engine as safe as possible. Once again, this is accomplished by knowing the customer, the customers driving habits, the customers vehicle, and its list of mods. You sell a product in a box and never know anything about the person purchasing or the vehicle it will be used on. These tune writers make a living and support their families by make good, safe tunes for individuals and their vehicles. If they build crappy running or unsafe tunes customers will go elsewhere, so they take the time to ask questions and get it right so their reputation stays intact. "One size fits all" tuners will never hold a candle to custom tuners or the custom tune writers that program them and that is a fact.
post #15 of 22 (permalink) Old 03-21-2011, 08:46 PM
mwilbur516's Avatar
No response Scott?
