Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 10-31-2009, 12:04 AM   #1 (permalink)
aerialjc's Avatar
Ram Air
I spent alot of time researching "ram air intakes" and found alot of good info on how the stock intake can handle a load of up to 500HP and decided to the "zoodad" mod. Not sure where the "zoodad" came from or means but it is just like any "ram air intake" on the market minus a high flow, multi-layer filter. If you look at the way the stock vs. aftermarket filters are setup, they look almost the same. I've had intake on other diesel engines and I believe no other stock intake compares to that of the 6.0L. It is the highest flowing stock intake of all the manufacturers. If you have own anything other than Ford you would know what I mean.
First I cut a rectangular hole, then I needed to find a way to keep debris from entering the intake housing and getting to the filter. There are several sites that sell a "zoodad" screen but I went to Lowes and purchased a screen for 4.95 and cut it to fit the hole I cut. Then I sprayed it with primer (covering the screen) then I screwed it to the radiator housing.
Job Complete. If the screen ever was to break or get clogged it would be very easy to replace.
5 Dollar "Ram Air"
aerialjc is offline
Old 10-31-2009, 12:04 PM   #2 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Fwiw I did the zoodad over a year ago. Cut as much as would be benifical and I didn't use a screen. I haven had any issues by not using the screen. I do admit it does dress it up a bith though
2004 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
sct x2 with custom tunes
315/75/r16 bfg km
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
