Replacing head gasket 6.0 diesel 2003 - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-15-2011, 09:26 PM Thread Starter
I am replacing the head gaskets on my 2003 F350 with the 6.0 diesel and need some help in finding out how to remove the high pressure oil line that passes down into the head from the oil rail. How do I remove it and do I need a special tool to do it? I can see a nut at the base of the line just above the head but there is not enough room to get a wrench in. Also does anyone know if the new ford head bolts any better then the original ones or should I go with the APR ones? The APR ones are very expensive!
back yard mechanic is offline
post #2 of 6 (permalink) Old 05-20-2011, 09:27 AM
I had the new ford ones done under warranty, they stretched in 2 weeks.
So unless you want to do this again, get the ARPs. Also make sure you send the heads to a machine shops, they are known to crack around the valve seats and be warped. This is a huge job, you don't want to do again.
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
- Video
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
05Duallyon22s is offline
post #3 of 6 (permalink) Old 05-20-2011, 12:24 PM
ex mounty's Avatar
My Photos: (19)
ARP head studs, $400
No longer a member of this forum
ex mounty is offline
post #4 of 6 (permalink) Old 05-20-2011, 12:41 PM
ford_doctor's Avatar
That oil line has a quick connect fitting and it does require a special tool to remove however it is not difficult to release the connector using an improvised tool that will push the black ring into the connector to release the spring clip. The connector has a tendency to stick and requires a little force to separate it. I use a prybar to do so.
You can get a look at the tool (or buy) it HERE but it is a little pricey if you are going to use it once. Looking at it might help you fabricate something.
To complete a head gasket repair you need to correct the cause of the excessive combustion chamber pressures. Check your turbocharger as it may be causing an over boost condition and have your PCM updated to a current level calibration which will mitigate over boosting.
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #5 of 6 (permalink) Old 05-20-2011, 04:09 PM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
I would put a new oil cooler in and save the factory bolts for something less important than a engine. They might make good scrap or a paper weight. As stated before the arps are about $400 shipped and not to hard to find for that price. Also make sure you have a clean flat mating surface and good heads. Do you still have a functioning egr system? Might also want to address that while ur there by welding up the cooler and making a delete out of it.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
post #6 of 6 (permalink) Old 05-25-2011, 12:58 AM
calabrese19's Avatar
<<< Just had mine done. Arp to the rescueeee
Tony
06 F350 Fx4 PSD
ARP HeadStuds - AEM BruteForce intake - MBRP 4" turboback-EGR delete - Ford blue fuel spring - 6.4 banjos - diy ccv
Viper 5900 remote start/alarm w/ one mile range - Pioneer D3 nav - 2500 watt power inverter - Harley headlights - Recon smoked cab lights - ebay 2.5" axle mounted leveling kit
DieselSite coolant filter- added at 39k
8ft WESTERN Pro-Plus w/ back drag blade
6000k slim ballast hi/lo H13 headlights and H10 fog HID kits from ddmtuning.com
to be done mods.. Innovative SCT X3, Edge Insight CTS w/ egt, oil bypass
88 mustang hatch- 347 stroker - for the strip
88 mustang vert- 4.6 DOHC gt-45 turbo - street car
calabrese19 is offline
