Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I just picked up a MAC Air intake. Very nice looking. I have a 04 F350 with a fairly new factory turbo and 100k on the motor. It runs great, but it will pop and carry on from the intake under slight load and at highway speeds. Sometimes it's fine driving around. I only had it on the highway once and it was pretty bad. What gives?
Probably the air intake air sensor. Several ait intake units have had problms with the sensor. Look there 1st. Hooked up right? Talk to the supplier, they probably have had to deal with this on other customers' trucks...
Ralph
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
How is it angled relative to intake air compared to the stock unit? If the angle is off, or the location has much different local flow, it will give false readings to the puter and you'll get strange behavior,
Ralph
Other rides:
If your filter is the oiled type, the most common type...
You may have had atomized oil contaminate the M.A.F. sensor.
Try taking it out and cleaning it with electrical contact cleaner, but DONT touch the sensor itself, The oil from your fingers will also cause it to give erratic readings.
All the luck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
JR44
2003, F-250, 6.0L PSD, Torqueshift, CrewCab, XLT,FX4,Short Bed, All Black Sport Model, Sunroof, Line-X Bed Liner, AFE Stage1 Pro-Guard 7, DPPI/MBRP T-304 Stainless Turbo-Back Exhaust, complete with CNC machined collar!
Banks Tecni-Cooler, Front,Rear Diff & 5R110 Mag-Hytec Pans, AutoMeter Cobalt Boost,EGT,Trans Gauges on A-Pillar, Bridgestone 285 Revo's, Bilsteins,SSBC V8 BRAKE CALIPERS, POWERSLOT CRYO ROTORS, Lund Smoke Bug Shield and Weathertech's AeroVisors on all windows. 16YR N.R.A. member, 14YR D.U. member, 10YR N.W.T.F. member. 5YR Delta Waterfowl member. www.rntcalls.com
Oiled filter can cause a big problem. Haven’t heard of any new from the box filters causing problems. It’s when people clean and re-oil their filters they cause problems or serious damage. DO not Repeat DO not over oil the filter, excess oil will coat the sensor, or worse get down into the engine and that’s all folks. Treat it like a boat B reak O ut A nother T housands or more for repairs. Best to clean the filter when you have a day or two. After cleaning let it air dry…
Trick – (If you have a newer style dryer with a shoe rack insert).
After rinsing off the filter, shake excess water off put it in the dryer on the shoe rack and set to air-dry no heat for no more then 20 minutes, repeat till dry. If you have, a good dryer set to lowest heat for no more then 10 -15 minutes let it cool off (do not let the filter get warm to touch) and repeat till dry. After it is completely dry (air dry about a day). Give it a light coat of oil let it sit so the cotton can soak in the oil. Then re-spray to even out the color and stop. Do not over oil, ever…. You can always add another (lite) coat of oil but removing it is not easy, using forced air as in an air compressor not recommended. Best to re-clean and start over. After you have cleaned and oiled the filter a couple of times you should have the hang of it, just remember that’s when your most likely to over oil it so don’t get sloppy or try to rush the process.
Also before, you start jacking things around on your truck, or running to the dealer call the Manufacturer of your intake, explain the situation there maybe a fix they can send you. If so your set – or are you.
It could be there is a minor problem with your truck that is not getting fixed or they do not have a fix for yet. Bummer at this point I would remove all after market add on products till the problem is found and resolved correctly. Otherwise, it could get ugly trying to get the problem fix under warranty. Sad but it is what it is.
05 F350 S/D Crew Cab 6.6'bed. Blk on Blk fX4, Up-fitter Switch Tow Command, Tow haul, Backup Sensors, Tow package upgrade, Crews Control, Keyless entry, & Base alarm. Dual Alternators/ Batteries, Sunroof, Electric Rear Window, 6-CD player, Full Electric Seats. 4inch lift, 18-inch polished aluminum wheels. Spray on bed liner & rubber bed matt.
Remote Start & Alarm, Entertainment Center, GPS & XM. External 12-volt power, Customized TracRac system with Yakama Road Warrior Rack and 520watts roof mounted off road lights. Adjustable tie down mounts on both side of the bed.
Extra 12-volt power in the cab, 3-gauge mirror mount, Trans temp, fuel & oil pressure. Rear air bags with onboard air compressor-in cab gauge & controller, plus more.
