Scangauge II X-gauges for 6.0 - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 18 (permalink) Old 06-15-2011, 08:05 PM
deliberate's Avatar
Originally Posted by U.P.Builder View Post
Is it possible to do the xgauge thing with the original Scangauge?
"The current software versions with XGauge are 3.14 and later, you can check this from the home screen and pressing MORE>MORE>MORE>VERSION
Version 3.14 was the release of the XGauge update, however the special functions did not work on Toyota Prius, version 3.15 was the release compatible with the Prius. The XGauge Feature will only work on ScanGaugeII, not the original ScanGauge"
See both ScanGaugeII - Upgrade and ScanGaugeII - Add-A-Gauge
HTH,
- Don
2010
F350 SRW 6.4L 3.55 CrewCab FX4 SB KingRanch - built Jan 2010 - bought new Dec 2010
"You can set my truck on fire, roll it down the hill, and I still wouldn't trade it for a Coupe d'Ville."
Rant: Do you know what you actually pumped into your tank on last fill-up? (cetane level, fuel quality, water, etc)
Notice: Anything that I or anyone else writes about my vehicle on this, or any other, website pertaining to modifications or alterations, is only for discussion purposes and/or to gain acceptance from my peers, and may not actually represent anything existing on my truck, and thus, can not and should not be held against me in any issues, i.e. warranty claims, whatsoever that may arise for any cause.
deliberate is offline
post #17 of 18 (permalink) Old 06-17-2011, 12:32 PM
U.P.Builder's Avatar
HTH,
- Don
I emailed Linear Logic and they said the original Scangauge 1 cannot be updated but they do offer a $30 discount on the Scangauge II for owners of the original. I'll probably order one since that will be the cheapest way for me to monitor EOT & ECT.
2004 F250 4x4 Lariat Supercab longbox, blue spring, coolant filter, Cat ec-1, 75k miles.
1996 F-350 4X4 reg cab PSD, BTS trans, 3.55, Bills Chip, Tymar, DPP downpipe, urethane bushings, Bilsteins, 203 thermostat - gone
U.P.Builder is offline
post #18 of 18 (permalink) Old 06-17-2011, 01:42 PM
deliberate's Avatar
Check the discounted price at Amazon vs, your $30 discount off retail. Note that some of the "standard" guages on the SGII do not necessarily work on the 6.4L (don't know about the 6.0L, sorry) apparently due to Ford's special CAN codes on the OBDII bus. For example: my MPH is way off and the XGAUGE for VSS doesn't work too well either. MPG is apparently totally out of the question, unlike the way it worked (well) on my old 1999 Exploder 4x4. Some XGAUGES which work for the 6.0L also do not work on the 6.4L so obviously other differences.
My SGII now works great on my 6.4L with XGAUGES for EOT and ECT. Also allows me to mintor exhaust gas temps before and after the DPF which then shows the huge boost during regen. Alas: no way that I know of to set an alarm like the Edge Insight offers.
Good luck,
- Don
2010
