Re: SCT ??
The code is called a strategy. You plug it in to the obdII port and click "read strategy" It will give you a code that starts with VX......... Then you take that call a sct dealear like Innovative or ELITE and ask for some tunes. When someone sells one that has been used they have to unlock it, because there code is stored.
Foe example, I had a code stock we will call it "code 1" I then had a reflash that changed it to "code 2" I then loaded my new tunes that are progrmamed to "code 2" when I returned it to stock, It put the "code 1" stock file back on. Because I forgot to unlock it.
But If they forget to unlock it. You should be able with no problem.
I say make sure you get it unlocked by them, because you will be so excited that you will forget to do it yourself.
2005 F-350 DRW 4.10's LS, Super cab, 8 foot bed, Larait, FX4 6.0L Auto.
Innovative Diesel = 4" MBRP Turbo back Cool Duals w/ 5" tips, Outlook monitor, Arp studs.
Pure Diesel = Intake Elbow.
Blackwidow Diesel = Spearco Intercooler.
ELITE DIESEL = Coolant lines, Cam, Valvetrain upgrade, Rods, everything else that they sell that goes in the motor, Stage 2 fuel system, Stage 4 injectors, FS2500, High Power Compound Turbos, SCT Tunes (Torque Tow, High Power, Insanity).
Suncoast = Complete tranny with Comp upgrade and billet shafts.
JimmiJammers and USMC Protected
Pics of CAB OFF: http://community.webshots.com/user/Zj0187
