Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 10-29-2009, 02:50 PM   #16 (permalink)
Strokin' 6.0's Avatar
Now, when you guys are talking tunes, you're talking PCM/TCM tunes only, right? Does the rule that the heads are going to fail, if you have the FICM programmed by Innovative or RCD or any other company, hold true?
SFC Fred Lynes
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch Package
Herrin Hauler Package
5R110 Torqshift
4.10:1 Dana 80 Trac-Lok
9,200lbs GVW
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Wishin' I still had my '05 2500HD CTD Ram
Strokin' 6.0 is offline
Old 10-29-2009, 02:54 PM   #17 (permalink)
HeavyAssault's Avatar
My Photos: (6)
There's no standard rule to tunes or anything being the single point source for HGs going. I'm running SCT and FICM tuning on stock bolts with no issues.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 10-31-2009, 01:24 AM   #18 (permalink)
aerialjc's Avatar
I tow a 6k boat every weekend with a bully dog tow program and I have 170k miles on my 2005 6.0L. I am a strong believer that if you bought your diesel and use it as a commuter/grocery getter you will have problems. If you use your truck like it was intended you will have no problems. With new trucks and all the EPA "BS" they have on them, you need to use them to their capacity or they will either clog up or run rough and need repairs.
Use the engine like it was designed and pull the crap out of it. You will have no more problems than the average gas gussling machine with routine filters and fluids.
aerialjc is offline
Old 10-31-2009, 12:19 PM   #19 (permalink)
We regularly tow our Airstream and gooseneck horse trailer, and I've still had a bunch of recurring problems.
From all of the research I've done, there's no rhyme or reason as to why these engines fail. Sure, preventive measures come in handy, but in the end it's still my opinion that the reliability of this engine is a crap shoot.
When I had my 2001 Dodge 3500, I took the original POS Carter lift pump off and replaced it with an AirDog FP100 fuel preparator. The OE lift pump was a known issue and I really don't know what Cummins or Dodge was thinking, when they put it on the engine block itself, but when it fails it takes out the VP44 Injection Pump. With a reliable aftermarket LP, the VP44 IP lasts a helluva lot longer.
I've done quite a bit to this 6.0 already (both legal and not so emissions legal), in the hopes that it would help, but now the FICM is dead.
I guess the thing would be to find a place, free from heat, to mount the FICM. Mounting it on top of the valve cover, next to the turbo and under the degas bottle is just plain stupid. Heat, heat and more heat is a recipe for eventual disaster. The biggest problem I can see with my idea is finding a harness extension to fit to the new location. The other possibility, and probably more practical, is ducting cold air to the FICM, to give it a fighting chance.
Has anyone tried this yet?
SFC Fred Lynes
King Ranch Package
5R110 Torqshift
9,200lbs GVW
Old 11-02-2009, 09:06 AM   #20 (permalink)
crfishon's Avatar
Send a message via Yahoo to crfishon
Originally Posted by teamroper60 View Post
Since it would be a felony to defraud the dealer and FMC, I don't believe I would follow this advice.
i took mine in with the programmer on it and they had no touble fixing it under warranty. no defraud, no felony..LOL!! i only say to take it off to be safe, talk to the machanic at the dealership and they can give you an idea as to how stricked they are. if you drive like a girl and dont chip out your truck you will probably be ok(unless your my daughter); but if you at all like to play or tow they are going to go again its just a matter of when!!
if you ask me the dealers defrauded us by continuing to sell them with out fixing the problem that they knew about from the start so who defrauded who?? LOL!! they have had so much trouble, this should ba a recall issue not a; oh crap!! can i pull this load without blowing my heads???
2005 F-250 CREW CAB 6' BED - 6" PRO COMP LIFT ON 20" RIMS W/THE NEW NITTO GRAPPLER M/T 35'S - AIRID AIR FILTER - 4" EXHAUST - MAG HYTEC DIFFERENTIAL AND TRANNY COVERS - ARP STUDS - BULLY DOG PMT - AMP POWER STEPS (the best) - VIPER AUTO START ALARM - PIONEER Z110BT NAVIGATION - A5 ROOF MOUNT SAT W/AUTO TRACKING - 12" FLIP DOWN DVD - PLAYSTATION 2 - PUNCH 45 - PUNCH 150 - MTX10" THUNDERFORM SUB - TRAIN HORNS (tied into alarm) - AND MORE TO COME!!! ><))))*> Fish On
crfishon is offline
Old 11-10-2009, 10:51 PM   #21 (permalink)
84k and head gaskets are blown again!!! First time dealer wouldn't hear of upgrading parts. It was covered at 40k, but now they want me to pay. So I guess I am gonna do it myself.
I pull a heavy 5er. And it is just a matter of time I guess with these motors the way they are from the factory.
I use a SCT but not when towing. And not a hot program just the normal stuff.
02 X 7.3l Ultimate Limited
06 KR 250 4x4
a94cobra is offline
