SCT Tuner Guys?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 09-24-2008, 01:53 AM   #1 (permalink)
SCT Tuner Guys??
Just got an SCT tuner with custom tunes from Innovative. I wanted to know first before I plug it in the port, do I need to do anything to save the stock program, or does it do it itself? If I need to save it, then how?? I have the X3.
Also, how do I return it to stock? And when I do, if I have to go to the dealer for repair,I heard they have a way to tell if a programmer was used, even though the truck is returned to the stock program,is that true??
Legend41 is offline
Old 09-24-2008, 12:02 PM   #2 (permalink)
GAZ4x4's Avatar
My Photos: (17)
The SCT will automatically store your stock program when you choose one of your custom tunes. Then when you plug it in at a later time to change tunes you will have the option to "return to stock" which reloads your stock tune back into the truck.
There has been alot of debate on whether or not the dealer can tell if you ran a tuner.
2005 F-250 CC/SB 4X4, 6.0L PSD-Torqueshift
med wedgewood blue,towcommand,upfitter switches
5"procomp lift with 5" Donahoe shocks and rear springs, 35"tires, 4.30 gears
BCP mod, LED taillights, 4"Banks exhaust, Harpooned fuel tank,
Accufab intake elbow, ARP Headstuds
Pioneer avic-D3 with backup cams and ipod
GAZ4x4 is offline
Old 09-24-2008, 07:51 PM   #3 (permalink)
expertrider's Avatar
...and AFTER you return it to stock, you must disconnect BOTH batteries for about 5 minutes and turn the headlights on.
You need to completely discharge the capacitors that can store the evidence of the reprogramming.
Its a good idea to keep the tuner in the truck, so if something happens when you're far from home, you can still return the truck to stock.
The SCT with Innovatives tunes is an awesome improvement over stock.
You'll be pleased!
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
expertrider is offline
Old 09-24-2008, 08:44 PM   #4 (permalink)
Thanks guys,hope this tuner can prevent the problems I've had so much,overheating,waterpump,bad egr cooler,egr issues. I use truck for daily driving and towing a boat,not into pulling or racing everyone.
Legend41 is offline
