SINISTER coolant filter INSTALL "W/PICs" - Diesel Forum - TheDieselStop.com
post #1 of 43 (permalink) Old 03-25-2011, 12:38 PM Thread Starter
usmarshls's Avatar
Just put on a Sinister Coolant filter kit yesterday.
Install time 30min
Tools needed 1- 10MM deep socket
2- 8MM deep socket
3- RAZER blade or some sort of cuting tool.
1- remove 10MM bolt from right Rad suport (The one with the star arount it) for the slow people :-)
2- remove the 8MM bracket from boost tube to turbo. (For easy cutting and install)
3- find heater core hose under boost tube
4- bolt on Sinister Coolant filter housing and lay out hosseseses.
5- cut heater hose before (heater vac valve)
6- place hose clamps on heater hose before instralling the blue T....
7- use 8MM socket to install hose clamps.
8- reinstall boost tube.
9- cut and install brass (T) to rad over flow tube
10- Install wix filter, open ball valves.
11- Start truck and check for leaks.....
ALL done... Install time was 30min or so.... you DO NOT need to drain any coolant just have a fet rags under the heater hose when you cut it.
DO NOT do this install when the truck/coolant is HOT....
ID:	10548   Click image for larger version
ID:	10549   Click image for larger version
ID:	10550   Click image for larger version
ID:	10551   Click image for larger version
2014 FORD F-250 CC SB FX4 6.2L 3.73 E-locker, black on Black inside, Blue Jean, NAV, SYNC, window tint, spray in bed liner
Added-
LED projector reverse lights
Factory upfitter switches
rear seat cover "kids are a mess"
LED floor lighting front and rear.
LED lights in bed under rails.
MORE LEDs coming soon.
SOLD
Goodbye my love
2005 F-350 King Ranch FX-4 CC long bed
2in level kit.airade intake with 4micron sock.superchips.sinister coolant filter.blue spring update.ranch hand wrench ready front bumperreplacement. installing glowshift gauges EGT,BOOST,TRANS TEMP,FUEL PSI. with quad gauge pod A-PILLAR.4IN turbo back cat delete
2004 F-250 V-10 -SOLD
1986 F-150 V-8 302CID first year of EFI -SOLD
1984 F-250 V-8 351CID Carb SOLD
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
usmarshls is offline
post #2 of 43 (permalink) Old 03-25-2011, 12:55 PM Thread Starter
usmarshls's Avatar
pics :-)
ID:	10553   Click image for larger version
ID:	10554   Click image for larger version
ID:	10555   Click image for larger version
ID:	10556   Click image for larger version
Added-
SOLD
Goodbye my love
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
post #3 of 43 (permalink) Old 03-25-2011, 12:56 PM Thread Starter
usmarshls's Avatar
more pics----- if you have any Q's ask.... I will be removing the filter in 3 months or so and cut it open to see the shi% in side it.....
ID:	10558   Click image for larger version
ID:	10559   Click image for larger version
Added-
SOLD
Goodbye my love
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
post #4 of 43 (permalink) Old 03-25-2011, 01:57 PM
aekrogh's Avatar
nice pics and good job.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
post #5 of 43 (permalink) Old 03-25-2011, 02:27 PM
fireguywtc's Avatar
Great write up with nice pics!
2012 F350 Lariat ultimate 6.7 PSD LB CC SRW Fx4,
67 F-250 Project truck, currently in a billion pieces
70 F-250 4x4 (highboy)
Past trucks: 07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust w/4" downpipe, SCT livewire
Traded in 04 F-250 xlt 6.0 PSD SB extcab 4x4, 6spd, all stock and 97 F-250HD xlt 7.3 PSD extcab LB 4x4, 5spd, Superchips tuner, 4" turbo back exaust, K&N CAI, 02 intercooler installed, Sold
fireguywtc is offline
post #6 of 43 (permalink) Old 03-25-2011, 03:57 PM
Banned
Thats a good looking kit!
LOOnatic is offline
post #7 of 43 (permalink) Old 03-25-2011, 04:23 PM Thread Starter
usmarshls's Avatar
lol ya the pics are from my cell phone too....
ya the kit is very well made it came all togeather and the bracket is super strong
and mounts better then some other kits
Added-
SOLD
Goodbye my love
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
post #8 of 43 (permalink) Old 03-25-2011, 05:07 PM
Band_Member's Avatar
My Photos: (64)
Nice installation and great that you took the time to take photos and share the process to help others. Hopefully the Mods will make posts like this Stickys so they're easy to find since a lot of people are doing these upgrades.
I just installed the Diesel Storm kit last week. You might not want to wait so long to change the first filter. Keep checking how hot the filter is with the engine at operating temperature . if the filter is cool then it is plugged. time to change it. I'm going to swap my first filter out at appox 1000 miles which would be about 6 weeks based upon my driving habits or sooner if it is cool to the touch when the engine is at O/T.
Again, great post. Thanks for taking the time and sharing the info and pics. Best regards.
2005 F250 XLT SC, LB
6.0 Torqueshift 3.73LS 4x4 T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2825 Hrs +/-, 101K Miles - No Major Probs other than brakes
DC Power 185 Alternator
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Centramatics
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
FP Gauge
Zerex Red ELC
Band_Member is offline
post #9 of 43 (permalink) Old 03-25-2011, 06:43 PM Thread Starter
usmarshls's Avatar
Thanks :-) i'll keep an eye on it.... im in the mid of installing a quad gauge pod this week.... just need to find a good 1/8 npt tap and have the a fuel adap on the way....
Added-
SOLD
Goodbye my love
In the Garage
1995 F-150, 460CID
2004 Expolrer 4.0L
post #10 of 43 (permalink) Old 03-26-2011, 04:27 PM
mwilbur516's Avatar
I've got the Dieselsite kit and my first filter needed to be changed at around 700 miles. You will be amazed at all the s*it in your coolant if you cut the filter open.
06 F250 XL, FX4, Upfitters, TBC, 15% window tint, 3.73's, Muffler delete, Cat delete, Fumoto valve, High idle mod, Zoodad mod, Harpoon mod, CCV mod, ARP studs, SCT Livewire w/ Looney Wild DD Tune, Dieselsite.com coolant filter, Glow Shift Fuel Pressure Gauge, Ford Blue spring upgrade, 6.4l Banjo Bolts, Upgraded turbo boots, Upgraded HFCM drain plug, Quick Tricks 58 volt FICM, S&B CAI, Monitoring EOT, ECT, EGT, IAT, Voltage and RPM
Horsepower is like a gun; You may not always need it, but it's nice to know its there
mwilbur516 is offline
post #11 of 43 (permalink) Old 09-24-2011, 03:49 PM
Installed the Sinister kit this morning,piece of cake 30 minute's done. I did not believe how dirty the anti freeze was when I cut the heater hose this is a must for a 6 liter.Thank's for the advice.
05 F350 6.0 AUTO FX4 SCT Extreme street by Innovative Diesel
RHJJ is offline
post #12 of 43 (permalink) Old 09-24-2011, 06:44 PM
U.P.Builder's Avatar
Thanks for taking the time to share.
I've got the Sinister kit sitting in a box waiting to be installed. Doing to whole flush thing, just pulled the starter to install Fumoto valves in the block.
2004 F250 4x4 Lariat Supercab longbox, blue spring, coolant filter, Cat ec-1, 75k miles.
1996 F-350 4X4 reg cab PSD, BTS trans, 3.55, Bills Chip, Tymar, DPP downpipe, urethane bushings, Bilsteins, 203 thermostat - gone
U.P.Builder is offline
post #13 of 43 (permalink) Old 09-25-2011, 11:47 AM
Cobalt Ford's Avatar
Awesome job with the pics!
I have the Sinister kit on the way, should be here Monday according to UPS. I also have a question: Is the turbo boost tube hard to remove and reinstall?
TIA.
2006 F250-XLT-CC-FX4 6.0,PSD
Cobalt Ford is offline
post #14 of 43 (permalink) Old 09-25-2011, 12:27 PM
You do not have to remove the boost tube just loosen the top clamp pull tube out of boot swing to side lay on top of alternator. You will have plenty of room.
RHJJ is offline
post #15 of 43 (permalink) Old 09-25-2011, 12:40 PM
Cool, thanks for the input.
