straight piped 6.0 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 06-27-2007, 07:30 PM   #1 (permalink)
straight piped 6.0
I have a MBRP 4" turbo back exhaust, and i was wondering if i take the muffler off and straight pipe it will the mileage drop alot?
06 F-250 6.0L FX4 Lariat Dark stone Crewcab, 6spd, 4" MBRP turbo back, SCT Tuner , Dipricol gauges (EGT and Tranny temp, boost), Cobra CB, drawtite Gooseneck hitch, Trail Ready Bumper, train horn
99jeep06stroker is offline
Old 06-27-2007, 07:35 PM   #2 (permalink)
PSV8TD's Avatar
Re: straight piped 6.0
My fuel mileage dropped maybe 1 mpg when I went from stock to MBRP 4inch cat back straight pipe.
2003 F250, 6.0L, Fx4, CC, SB, Lariat, Arizona Beige, MBRP Turbo Back Straight Pipe 4inch, Bilstein shocks, Isspro pyro and boost gauges, Banks Six Gun & Speedloader, Auxillary idle, XM radio, CB, Backup lights, Recon Smoke cab & mirror lights, Timbrens
PSV8TD is offline
Old 06-27-2007, 07:41 PM   #3 (permalink)
Thanks man, anybody have different mileage change with turbo back?
Old 06-27-2007, 11:14 PM   #4 (permalink)
weasel79's Avatar
I think I might have gained 1mpg but I didnt lose any. And it is a true straight system.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe, tire clearance and guage photos
weasel79 is offline
Old 06-28-2007, 04:03 AM   #5 (permalink)
darsey715's Avatar
you might lose a couple mpg's cuz you'll be getting on it so often at every stop light.
darsey715 is offline
Old 06-28-2007, 11:03 PM   #6 (permalink)
Smokewagun's Avatar
My Photos: (9)
So, I have an MBRP cat-back on my 2007 6.0L. I want more whistle and more notice. The MBRP sounds good, but no whine and nobody really cares to hear it. I debated about the delete pipe for the muffler. Now, I want it. The problem is that I will destroy the exhaust piping as I will have to cut the muffler out because the clamps kink the pipe and muffler inlets/outlets in order to tighten them up enough to keep the system from working loose. So, what is the best way to go about removing the muffler? In addition, because I have to cut out the muffler, the inlet pipe and tailpipe will now be too short to accept the delete pipe - or the section cut out with the muffler will be too large to just insert the delete pipe. Where can I get some more 4 inch pipe with a flared end? The MBRP muffler is flared on the inlet and outlet, so after I cut it out, I will need some more "parts". Have any of you just turned the exhaust out just past the kitty? Will it destroy my rear wheels with soot? Thanks,
Smoke.
2010 Ford F-250 Superduty Harley Davidson. Navigation. Moon.
Smokewagun is offline
Old 06-28-2007, 11:21 PM   #7 (permalink)
darsey715's Avatar
Smoke.
if you want more whistle you're gonna need a 4" dp assuming you leave the cat in. I would suggest cutting your 5 or 6 inch tip off, then welding it right after the cat pointed down or out to the side. simply deleting the muffler isn't gonna do too much. you have a few options with exhaust.
