Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 11-03-2004, 11:10 PM   #1 (permalink)
My Photos: (26)
Superchips version 5.03 after almost 6 weeks
I sent my SC1704 in to "Vic" at Superchips to fix the harsh shifting and the hanging in gear. It is back 6 weeks later because "Vic" had to spend over a week testing and changing the shifting program. Don't ask where the other 4.5 weeks went. Now it has stock like shifting unless full throttle where you get a firm, quick shift which is needed. The power delivery is the same as the previous unit which I wish was more like the Quadzilla. If only I could have the power of the Quad 160 and the shifting of the SC1704. I do like the SC shifting under full throttle at 3900 rpm, it screams!
So:
*The harsh shift is gone.
*No slips whatsoever.
*No more "hanging" in gear.
The SC1704 version 5.03 is much more refined.
Mark
2004 Superduty CC SB 4x4 PSD 6.0 Torqshift|ISSPRO Gauges www.dieselmanor.com |Edge 4.5 lift|315/70/17 BFGs|17x10s|Xtreme SCT Tune by www.InnovativeDiesel.com |4" Cat-Back straight pipe|John Wood Built 5R110 www.jwtt.com|ARP Headbolts|Modified AIRAID Cold-Air Intake|ZOODAD MOD |Pioneer W/XM Head Unit|Alpine Amp|10" MTX Sub|440 RWHP
http://photos.thedieselstop.com/show...=36994&thumb=1
VegasSuperDuty is offline
Old 11-04-2004, 02:43 AM   #2 (permalink)
MPD224's Avatar
My Photos: (16)
Re: Superchips version 5.03 after almost 6 weeks
Does version 5.03 give you any smoke? I have version 5.01 and it hardly throws smoke, just a little when I get on it in the HP mode.
2004 F250 XLT Sport FX4 Crew Cab SWB, TorqShift, ESOF, 6.0, True Blue, Black Leather Captains Chairs, Moonroof. Built 04-05-04
Mods: ISSPRO gauges in under cubby pod. MBRP Dual exhaust turbo back (straight piped). AFE Stage 2 Intake w/ Dry S filter. Fumoto Valve. Harpooned tank(pics in my gallery). 33X12.50X20 Toyo M/T. 20" XD Monster's (Black). ARP Head Studs Installed on 12-11-07 w/ OEM Heads
Pics
MPD224 is offline
Old 11-04-2004, 07:50 AM   #3 (permalink)
Bear_Hunter's Avatar
My Photos: (9)
So:
Mark
Well....Well...Well...finally huh? Mine seemed to fix itself after putting on 39.5" tires...seemed to cure the "rough" shifting....maybe the extra weight of the tires?
TRUCK PICS Lifted by Truck-Toyz
JAKD 2007 Dark Stone Harley Davidson Edition Super Duty Custom Built By Trucktoyzperformance.com
Special Thanks to: Trucktoyzperformance, Autometer, Rize Industries, MBRP, Line-X of Friendswood TX, Accufab Racing, Painless Performance, Retrax, OilGuard, and DC Customs
Also brought to you by Critical Fight Gear & Suckerpunch Entertainment
Bear_Hunter is offline
Old 11-04-2004, 09:27 AM   #4 (permalink)
What? [img]/ubbthreads/images/graemlins/eek.gif[/img] Mine smokes like a coal train in the HP mode. Very little in the Economy mode and like stock in the Tow Mode. I keep it in the tow mode most of the time. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Member: CO PowerStroke Club/Good Sam/Camping World-
2004 F250 Lariat 6.0 SD LB SC Wedgewood Blue Build date May 2003 with latest flash 05/26/05, 4" cat back with afe proguard 7 air filter, 50 gal. transferflo with tool box & Trax Command, LineX, "Brite Box", Pyro,Boost, &Tranny Gages "piller mount", C'Betr Mirror's, Cab Fresh Cabin Filter, Fumoto Drain Valve. Superchip Programmer, Timbrens, BrakeSmart, Garmin NUVI GPS.. Other: 2005 35ft. Gulf Stream Prairie Schooner
lheebie is offline
Old 11-04-2004, 10:09 AM   #5 (permalink)
FamilyRide's Avatar
Mine was updated to 5.01 back in the summer and shifting was the only thing that changed. I've heard some with 5.02 say smoke was greatly decreased. Mine will still smoke like a train in HP and stil pretty good in Econ. pretty easily. I'm running Tow Tune now (for the first time for any length of time) and I'm much happier with shifting (stock shift points) than with HP or Econ still. Econ and HP are much better now, but Tow is much better running around town.
I'd be happy, but I found out after, that 5.01 did not in fact support the latest '04 reflash so I'll have to send mine back "again" for a new flash. Or, try something new.
Any other changes that you can see/feel?
PS. I have my EGR disco'd right now until I can get it in for a new EBP, and I noticed less smoke while disco'd that while it's connected. Could be something to the "more air" theory.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 11-04-2004, 02:30 PM   #6 (permalink)
My Photos: (26)
Family,
The shift points are at the stock setting unless WOT in all settings. Only at WOT will you shift later. The Econ file seems like a full throttle on/off switch as far as power delivery, I am going to try HP this afternoon and see if I get any better lowend. I know the tow mode has lowend but I like top end as well. Again the Quad has the best power delivery but I want my tranny line pressure increased as well.
