Taking cab off to change head gaskets - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-30-2005, 03:28 AM   #1 (permalink)
A lot of shops are pulling the cab instead of the motor to do head gaskets. Anyone try this yet?
2000 F-350 Lariat SC PSD SRW 4X4, Six speed, Dark toreador red, Ball Bearing Turbo, Coolmist Stage 2, Banks Big Hoss 5 chip, Big Head Actuator and 3.5 down pipe with Dynomax exhaust, PacBrake Exhaust brake, AIS Air Filter, Jordan brake control, 20K Reese fifthwheel Hitch, Reese folding gooseneck hitch, Rhino lining born 5/00
1998 35' Challenger fifthwheel double slide with 3600 Onan MicroQuite Generator,Washer/Dryer.
Wife drives a Black 2003 Excursion 4x4 Limited, 6.0 PSD
diesel_doctor is offline   Reply With Quote
Old 07-30-2005, 06:44 AM   #2 (permalink)
Re: Taking cab off to change head gaskets
I don't think either has to be done to do head gaskets. I found one of the best tips I have ever heard in one of the recent threads. Somebody mentioned dropping studs in the bolt holes while the head is off the motor. Then you use rubber bands to hold the studs up so they don't drop thru the holes when you lift the head That way you can install the head with studs without removing either ther cab or motor.
2005 3500 Cummins HO NV-5600, 3.73 LSD....One box, two turbos, 2 pumps and 6 big sticks
871 HP #2 only
Co-President Mason-Dixon TDC
maximumstroke is offline   Reply With Quote
Old 07-30-2005, 07:50 AM   #3 (permalink)
why would you remove the studs? the idea of using studs is that they torque more acuratly than bolts. any stud use i have ever seen keaves the studs in there.
04crew is offline   Reply With Quote
Old 07-30-2005, 07:52 AM   #4 (permalink)
i have seen the front end removed in one piece for major engine work or engine swap.
Old 07-30-2005, 12:43 PM   #5 (permalink)
Go to www.flatratetech.com they have a fair amount of info there. Thats how I am gonna do my 6.0 since it is a regular cab. Not sure I would do a crewcab that way though cause part of the interior has to come out to get the middle cab bolts.
Proud Recipient Of The \\\ 01 F-350 CC/LB 4x4 BTS Auto XLT Toreador Red W/Gray Lower Accent
10" Lift 38 PJs, EDGE Trac Bar Relocate, ORU X over, Weld Outbacks, AFE Stage 2,Hypermax 5", Hypermax Mod BJ Code Injectors, Hypermax H2E (broke, replaced with something bigger), Hypermax Rev Kit, ITP Fuel Sys, Aeromotive fuel pump, forged rods, main studs, head studs, billet intakes, WOP fire rings, BTS Trans & HPOS,
99 F-250 Reg Cab 4x4 Auto, Project truck,
97 F-350 Reg Cab 4x4
96 F-250 Reg Cab 4x4 Auto, Stock/Wrecked AVAILABLE
03 F-250 Reg Cab 4x4 Auto 6.0, Studded, EGRless, Hypermax Injectors/Firerings/5" exhaust, AFE Stage 2, Electronics vary DEAD
SDCRM #13
Agree? Disagree? Wanna Talk Trucks?
(785)243-4879
<font color="red">KANSAS members, PM me. </font>
Nick Gerard is offline   Reply With Quote
Old 07-30-2005, 09:34 PM   #6 (permalink)
no, sorry about the confusion. That is not how I meant for you to take that. What I was talking about was if you were to do a gasket swap and install studs at the same time. Granted if the studs were already installed previously you may or may not want to take them out to do a head gasket. This is just a way to do the job without removing the motor or cab.
871 HP #2 only
Old 07-30-2005, 11:41 PM   #7 (permalink)
DSI
my truck was just finished friday, the core support was removed, but not the hood or fenders, the head's were removed while the block was still in teh truck, the head's with the stud's rubber banded on them were re-installed in the truck. there was room to work, and get even torque on all studs.
and it doesn't puke on demand anymore [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
'04/03 F250 6.0/Torqueshift XLT Crew Cab... 4in, 4.10's, 315's on weld's, Stud's, O-Ring's, Injector's, Fuel Mods, AFE Intake, and a MagnaFlow Exhaust...
DSI is offline   Reply With Quote
Old 07-31-2005, 08:47 PM   #8 (permalink)
New to the 6.0 so sorry for the dumb question. Why are you pulling the heads on your trucks?
2011 F450 K/R ALL Stock and staying that way
2001 F250 Lariat. BTS, DP Tuner, Banks inter-cooler, Banks Turbo upgrades, Banks Exhaust, Banks Exhaust brake,
edinning is offline   Reply With Quote
Old 07-31-2005, 08:55 PM   #9 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Under power headstuds will "strech" and allow the cylinder pressure to blow into the coolant passages, thus causing the truck coolant to "puke" out the overflow container (I should have the basics correct). You should replace the head gaskets after this due to an increased risk of it happening again.
While there are reports of this happening on stock trucks, this is not a common occurance.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote
Old 08-01-2005, 07:07 AM   #10 (permalink)
[/ QUOTE ] <font color="blue"> I had it done and it looked to be a piece of cake. They raised the entire cab of my crew cab and then had lots of access to the engine. Not a scratch on it anywhere. Took a little less than 1.5 days of actual work including diagnosis. I was very pleased. </font>
Troutly is offline   Reply With Quote
Old 08-01-2005, 07:43 PM   #11 (permalink)
lco
^how much did that cost
lco is offline   Reply With Quote
Old 08-01-2005, 10:05 PM   #12 (permalink)
<font color="blue">
The warranty claim was $2,207. There are several misc parts and fluids (oil / coolant) that need to be replaced when doing gaskets / bolts. </font>
Old 08-02-2005, 06:48 PM   #13 (permalink)
What HP or mods are causing the heads to have problems? Are the 05 doing this or has Ford corrected the problem? Thanks
