Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 10-26-2007, 10:21 AM   #1 (permalink)
MDub707's Avatar
Torque Converter Lockup Questions.
Ok so this is the first vehicle I've ever had to worry about the transmission in, and I'm wondering about the TC lockup. Obviously the benefits would be a stronger "grab" from the transmission, but what does this mean? Will it wear out quicker? Seems like it may last longer as its not slipping at all!? Can someone explain the positives and negatives of this addition? I'm sure there are others out there with the same questions. I may have gone with the Xtreme Race tune, and may still, but want some more info. What would happen say if you were doing a bumper to bumper pull with another truck? Would you want a lockup or not?
Also question for Innovative - would you be able to make it so you can run a TC lockup on the Xtreme Street tune?
Thanks guys and gals.
DamnKids Motorsports
-Mike-
2006 F-250 6.0 4x4
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
2005 Honda 450R - Under construction
2005 Kawasaki KLX110 - slow
tworocks - "yes I can smell it, but it smells better than my wife, so no complaints."
MDub707 is offline
Old 10-26-2007, 02:15 PM   #2 (permalink)
Mark Kovalsky's Avatar
Re: Torque Converter Lockup Questions.
You want lockup when the torque converter is in a range where it is not multiplying torque. That's when the stock torque converter locks in 4th and 5th gears. It will not lock in the three lower gears.
You would gain some power to the ground if you locked the torque converter after it is at a speed and load where it isn't multiplying torque any longer. If you locked it before this point you would have less torque to the ground. And if you locked it WAY too soon it would slip as the pump wouldn't have enough capacity to keep it locked at lower speeds.
Mark
Mark Kovalsky is offline
Old 10-26-2007, 02:17 PM   #3 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MDub707</div><div class="ubbcode-body">
Thanks guys and gals. </div></div>
I can't 100% speak for Eric @ ID, but one of the main difs of Xtreme street and race is the TC lockup, so yes he could lock it on Xremestreet but then you might as well call it XtRace...
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, Mac Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane!
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting and 3rd Brake lights.
05Duallyon22s is offline
Old 10-26-2007, 03:04 PM   #4 (permalink)
InnovativeDiesel's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 05Duallyon22s</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MDub707</div><div class="ubbcode-body">
</div></div>
That's correct.
Innovative Diesel Performance
410-620-3020
http://www.innovativediesel.com
The Original SCT Custom Tuning Dealer!
We are the first and most experienced custom tuner for the 6.0L truck!
*No gimmick's and no marketing ploys.*
Only the best custom tuning, from stock to highly modified trucks. We have a proven track record and tune the fastest and most powerful Ford vehicles in the industry.
IDP thrives on carrying only the best parts and great customer service. Over 5000 parts ready to ship for your diesel truck!
InnovativeDiesel is offline
Old 10-26-2007, 04:19 PM   #5 (permalink)
MDub707's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mark Kovalsky</div><div class="ubbcode-body">You want lockup when the torque converter is in a range where it is not multiplying torque. That's when the stock torque converter locks in 4th and 5th gears. It will not lock in the three lower gears.
You would gain some power to the ground if you locked the torque converter after it is at a speed and load where it isn't multiplying torque any longer. If you locked it before this point you would have less torque to the ground. And if you locked it WAY too soon it would slip as the pump wouldn't have enough capacity to keep it locked at lower speeds. </div></div>
That kind of contradicts what the guys at Innovative originally told me when I purchased my tuner... here is what they said..
" Xtreme Race- 420-440rwhp/760-780rwtq - Converter locked in all gears.
Xtreme Street- 420-430rwhp/730-760rwtq- Not recommended for towing.
Street- 400rwhp/670rwtq- Tow up to 10k lbs.
Tow- 350rwhp/630rwtq- Towing over 10k lbs up to the maximum of the truck.
Economy- Mileage program only.
So it only locks it in the higher gears or what? So I guess a truck pull you wouldn't be using this feature than anyways.
So with just a TC lockup you can really gain that much more peak power and torque?
-Mike-
2006 F-250 6.0 4x4
MDub707 is offline
Old 10-26-2007, 10:35 PM   #6 (permalink)
I don't see where they contradicted what I said. What you posted doesn't say anything about the stock calibration, and that's what I was describing. The stock calibration only locks in the two top gears. A tuner can make it lock in whatever gear they want.
Locking the torque converter doesn't gain ANY power or torque. The tuner is increasing the engine power and torque, but that doesn't have anything to do with the torque converter lock.
Mark
Old 10-27-2007, 01:23 AM   #7 (permalink)
MDub707's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Mark Kovalsky</div><div class="ubbcode-body">I don't see where they contradicted what I said. What you posted doesn't say anything about the stock calibration, and that's what I was describing. The stock calibration only locks in the two top gears. A tuner can make it lock in whatever gear they want.
Locking the torque converter doesn't gain ANY power or torque. The tuner is increasing the engine power and torque, but that doesn't have anything to do with the torque converter lock. </div></div>
Ok I didn't understand, I didn't realize you were talking about stock. So then from what you posted earlier the ID tunes will actually put less power to the ground with a TC lock in all gears?
Also 05superdutyon22s said that the Xtreme street and the Xtreme Race are the same, save for the TC lock up, ID agrees but posts two different power ratings for them. Thats what is confusing me I guess.
So again back to my original questions. Will it wear out faster? What are the benefits or negatives of doing this and what would happen if you were doing pulls with a TC lock?
Also both
-Mike-
2006 F-250 6.0 4x4
MDub707 is offline
Old 10-27-2007, 01:23 PM   #8 (permalink)
*IF* they lock *BEFORE* they should, it will put less torque to the ground. *IF* they lock when they should it will put *MORE* torque to the ground. It is not a simple yes or no.
Maybe if you went to http://www.howstuffworks.com and looked up torque converters you'd understand better. It would take me pages and pages of typing to explain how the torque converter works. You really need to understand how a converter works to be able to make decisions like that.
Mark
Old 10-27-2007, 03:53 PM   #9 (permalink)
MDub707's Avatar
Ok thanks, I appreciate it. I'll read up like I originally planned and ask questions then. I was just simply wondering more along the lines of the benefits and negatives of locking it in more gears, along the terms of wear. Thanks, Ill do some reading.
-Mike-
2006 F-250 6.0 4x4
MDub707 is offline
