Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 07-06-2008, 12:27 PM   #1 (permalink)
Truck VIOLENTLY shaking after lift
so I have about 150 miles on my Icon 4.5" kit. truck drives good on the highway, fine around my house. I was told to see if there is a vibe as I have a CC and I may need the carrier shim kit. nothing I can really feel during normal driving before today. now there is a road a few towns over that has some "bumps" in the road. kind of like where the road was pushed together in one spot and made a hump across the roadway. well....I went over one today at about 50 mph and the truck started to VIOLENTLY shake. I thought a wheel was falling off and i jammed the brakes. got down to 25mph or so and it stopped. hit another one and it started again. came up to a 3rd one and got off the gas to coast over it...same thing. I mean...the truck is litterally jumping around back and forth violentyl and make me pretty nervous...nervous enough to take the lift out. no way can this be related to the carrier not being shimmed can it?? thanks for all your help
Jake
Silver '07 F350 PSD CC 4x4
Recon Smoked Cab/Mirror lights
Icon 4.5"
Amp steps
Silver '03 Cobra Coupe Auto
10.26 @ 138 w/ a 1.46 - street driven
BADASS03SVT is offline
Old 07-06-2008, 04:22 PM   #2 (permalink)
My Photos: (13)
I am almost 100% positive, your factory steering stabilizer is wore out. There is also a FORD TSB, that will tighten your gearbox down. I prefer going w/ the DR/ICON Dual stabs. Even though it is pricey, it is worth its weight in gold. Ford really messed up, putting the steering stab where they did, FYI.
2007 Ford F250 CC 6.0 4x4 Lariat Outlaw Edition, 7" DR Lift, 37/13/22 Toyo M/T's, 22x9.5 KMC Black Hoss, AFE Stage 2 P/G 7 w/ Pre-Filter, SCT w/ DJ's Looney, MBRP Turbo-Back Off-Road Exhaust, Kenwood 8120 DVD, Valentine One, Amp Steps, 08 Shaved Rear End Conversion, 08 mirrors, Recon Tailights, 3rd Brake Light & mirror lights, Mag-Hytec Diff Covers & Trans. Pan, Royal Purple Everywhere, Retrax Bedcover.... much more to come...
*sold 2/06* 2000 Ford Excursion Limited Diesel 4x4. D/I 4 pos. 4 bank Chip, Suncoast Conv, AFE Stage 2 Intake, 4" Exst, A-pillar w/ Autometer C2's (pyro, tranny, & Boost)Superlift Tru-Speed, 4.56 gears, 15" Atlas Springs, 4.5 Edge Hangers, Edge X-over Steer., Edge T/B Relocation, 12" Atlas Rear Springs w/ a 7" Shackle Reversal Flip, 44/21/16.5 STS on 16.5 X 14 Weld Mountain Crushers, Amp-Research Steps, Shaved Tailights w/ Custom Rollpan,DRIVEN DAILY X-pics *SOLD 2/06*
V_P_O is offline
Old 07-06-2008, 05:08 PM   #3 (permalink)
this truck sees no offroad..is it worth the coin?? benefits?
Jake
Icon 4.5"
Amp steps
Old 07-06-2008, 06:38 PM   #4 (permalink)
RAVOwner's Avatar
Definately worth the coin. I have a 6 inch lift with dual pro comp stabilizers and the truck handles great. My truck only sees offroad when I pull into my jobsite parking lot. I have taken a few rides in my buddies F250 with a 6 inch lift without stabilizers and his hand looks like it is going to snap off when we get on some wornout roads.
05 F350 SRW CC LB FX4 Lariat
6 Inch Procomp Lift / Superlift Stainless Steel Brake Lines (Front and Back)
20 Inch Weld Racing X-Lander Chrome Wheels with 35x13.50x20 Procomp Tires
Oilguard Bypass Oil Filteration System
Dieselsite Coolant Filter and External Transmisson Filter
4 Inch MBRP SS Turbo Back Exhaust with Muffler Delete Pipe (The Kitty is Safe for Now)
Roll Lock Bed Cover
Quadzilla Recon XZT gauge (Boost, Trans, EGT)
RAVOwner is offline
Old 07-06-2008, 07:52 PM   #5 (permalink)
My Photos: (13)
Yes it is def. worth the extra money. Just as you purchased the Icon lift over anything else. It is all backed by a lifetime warranty. Your lift is not causing it, its the wider oversized tires, taking over the factory steering stab.
When it gets bad enough, alot of people notice the EXACT same conditions w/ a no lift and factory tires. DR/Icon stabs solve the problem!
V_P_O is offline
Old 07-07-2008, 04:30 AM   #6 (permalink)
DecreasingDave's Avatar
Two words: Death Wobble
....and no, a steering dampener will not fix it.
I don't know everything about this phenomenon as the leaf spring trucks don't have this issue but IIRC, there is a TSB about it and I believe it has to do with a front end alignment.
I'd check into that first before spending ANY money on anything else. You may be only masking a potential hazard that will get back at you down the road.
Dave
2003 F-250, 4x4, CC, SB, 6.0 PSD w/Torqshift, Lariat, Toreadore Red/Arizona Beige
- Airaid intake
- MBRP Turbo-Back Exhaust
- Cross Over Fuel Line and 1/2 Banjo Bolt Mod
- Quadzilla Commander
- Zoodad Mod.
- Doorseal Mod.
- X-Springs and F-350 Blocks
- Full Traction 4.5" Hanger lift
- ProComp Add-A-Leaf and Velvet-Ride shackles
- BFG 35" All Terrains on Ultra predator 17x10s (Hub-centric)
- Timbrens
- Extang R/T Tonneau Cover
- C.R. Laurence PowerSlider Rear Window
- Sirius Sat. Radio
- Polk Ex3 5x7s and 2 JL Audio 10w0s
driven by a 6 channel amp
- SCT from Innovative (WOW!!)
DecreasingDave is offline
Old 07-07-2008, 06:28 AM   #7 (permalink)
ok...will look into it
Jake
Icon 4.5"
Amp steps
Old 07-07-2008, 09:38 AM   #8 (permalink)
My Photos: (13)
Dave
you know why the leaf-sprung trucks dont have it ?? Its because Ford put the steering stab in the CORRECT place, along the tie-rods, close to the tires.
In 05+ they are along the drag-link, opposite the steering box. The way they positioned it, it actually MAKES death wobble. But each to its own. I have an 07, and corrected my death wobble. My truck drives PERFECT w/ no issues. I simply REMOVED the factory stab, and installed the ICON dual stab. It solved all of my issues.
Ive also installed several of these dual stabs on 05+ STOCK trucks, and the customers call back the next day, thanking me. I must be doing something right.
V_P_O is offline
Old 07-07-2008, 10:03 AM   #9 (permalink)
Where can I get one? My stock one is starting to be an issue.
kman780 is offline
Old 07-07-2008, 12:03 PM   #10 (permalink)
My Photos: (13)
Truck Toyz Performance .. Experience Matters! Marty is a supporting vendor of TDS!!!
V_P_O is offline
Old 07-07-2008, 01:17 PM   #11 (permalink)
just to calrify...stock wheels and tires on truck.
most of the posts to me have been about the stock stab and alignment. seem slike a good starting point
Jake
Icon 4.5"
Amp steps
Old 07-07-2008, 10:07 PM   #12 (permalink)
Did I strike a nerve?? I didn't mean to, I was just trying to help the guy out.
I stated in my post that I didn't know that much about it. I do know the the TTB set-up had the same issue. Was that stabilizer set-up the same design??
Dave
- Airaid intake
- Zoodad Mod.
- Doorseal Mod.
- Timbrens
- Sirius Sat. Radio
Old 07-09-2008, 09:28 AM   #13 (permalink)
Thanks, are the shocks they offer any good or should I get others? The 5500 series they offer are the same brand as the kit so it should probably be fine.
Let me know, if you get a chance. Thanks for the info.
kman780 is offline
Old 07-10-2008, 02:10 AM   #14 (permalink)
hypersnyper694788's Avatar
I guess im lucky but i have a 6" lift with 37's and i dont have a problem. I definitely have a shim kit though. I was told to get a steering stabilizer but i have not got around to it yet, but i have not had any problems.
06' F250 CC SRW Lariat, 6" fabtech lift w/ bilstein 5100's, 20x10 polished eagle alloy 114's, 37x13.50x20 Nitto Mud Grapplers, 4" mbrp, 2 jl audio 10's
hypersnyper694788 is offline
Old 07-11-2008, 12:20 AM   #15 (permalink)
My Photos: (13)
Talk to Marty or Kevin @ Truck Toyz. They prob. have Bilsteins in stock for the kit, but im not sure. Just ask them :-)
V_P_O is offline
