Turbo Boot Clamps?? - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 01-28-2006, 06:44 AM Thread Starter
Turbo Boot Clamps??
Mine have blown off twice now and left me high and dry. Are there any after market clamps and boots that actually hold?
Thanks, OSD
oldskooldave is offline
post #2 of 15 (permalink) Old 01-28-2006, 08:53 AM
FamilyRide's Avatar
Re: Turbo Boot Clamps??
I doubt there is much of an aftermarket for them. It's rare to find one that when cleaned up and put back on properly, or replaced by the dealer with the new ones (depending on which you're talking about) that keeps popping off.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #3 of 15 (permalink) Old 01-28-2006, 01:37 PM
Boost Clamps
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #4 of 15 (permalink) Old 01-28-2006, 03:05 PM
FamilyRide's Avatar
Bad link...actually, no link.
post #5 of 15 (permalink) Old 01-28-2006, 04:38 PM
I am blowing off my Banks blue ones (the double thick ones). We are going to clean them (they get real oily from the CCV), and glue/double clamp them. I may also reroute the CCV.
RL
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures:
6L Shootout Report:
ralphinnj is offline
post #6 of 15 (permalink) Old 01-28-2006, 05:35 PM
http://www.turbohoses.com/
2000 f250 4x4 lariate woodland green metalic and gold on the bottom.sharp looking super cab.100,000 miles .air heater mod,CCV mod,zoodad,80 econo DP tuner PCM ,cranked doun stock waste gate,cubie hole type gauge pod,k@n replacement filter.sonax/tricumulator, map sensor pop off valve,boost tube,BTM ,code eliminators ,wiked wheel,EBPV deleat ,hp oil cross over feul presure shimed and gauge, Heater core hose bypass valve .Wet Okole seat covers with Powerstroke logo ,.home made donaldson intake in the works parts on order.mounting bracket and 45* silicone elbo.piss on this homemade thing it will never be as good as the AFE stage II.thats what i'll get next.i am curently running my stock air box
WUNDERHOOT is offline
post #7 of 15 (permalink) Old 01-28-2006, 09:16 PM
I had trouble with mine when pulling 6% grade. I cleaned them off good with carb cleaner and got back home. I took them off at home and then cleaned up both pipe and hose again then sprayed them with Auqua net hair spray before putting them back on. No problems in the last 40k miles.
2003 F350 SuperDuty CC Lariat SB Torqueshift,Front leveling kit, 285/75/16 Toyo MT's,Eagle Alloys,AFE Magnumforce,ITP Muffler Delete, Leer Canopy.
1979 F250 4x4 Built 400 4 speed 4 in.lift
2000 Weekend Warrior 26ft Toybox
2004 Yamaha V-Star 1100 Classic
bikerforchrist is offline
post #8 of 15 (permalink) Old 01-28-2006, 10:32 PM
Mine kept blowing off especially when I was towing. Ford finally replaced it with a new hose that has a spring wrapped around the outside of it. Thats been almost a year now and it hasn't moved at all so far.
-2003 Ford F350 SRW CC LWB 4x4 6.0 6spd 35" M/T's 3.73's Sonic Blue Roll-Along Package
-1999 Dodge 2500 QC LWB 4x4 8.0 Auto 33" SSR's 4.10's Flame Red
-1999 Trans Am 5.7 Auto Black
SOCAL is offline
post #9 of 15 (permalink) Old 01-29-2006, 05:36 AM
Aqua net hair spray? What function does that do?
I had the lower tube/hose blow off and with knowledge gleaned here I did not panic, I limped home blowing a lot of smoke and making a lot of turbine noise.
Called moderator Super Duty John and he hooked me up with some plumbers pipe jizz that is oil resistant. Never blew off again but I suspect the next guy that tries to get it off may have challenges.
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
post #10 of 15 (permalink) Old 01-29-2006, 06:15 AM
I believe it acts as a friction element or glue-like.
RL
Other rides:
Pictures:
6L Shootout Report:
post #11 of 15 (permalink) Old 01-29-2006, 07:06 AM
RL
I sort of figured. The problem as I see it is not that the clamps are insufficient but there is so much damn oil in there it just slips off.[img]/ubbthreads/images/graemlins/smokin.gif[/img] There has to be some modification that doesn't route all that oil fumes in there. Oil in the tubes and CAC can't be contributing to efficiency.
post #12 of 15 (permalink) Old 01-29-2006, 10:23 AM
The CCV line is to blame. The solution is to re-route it so that it does not recylce into the turbo. I have not done this yet, but the best thing I have heard is to set up a small decanter that can vent. Every so often, you have to drain the oil. That would keep oil out of the entire intercooler system. If anyone has a "kit" for this, i would be interested in hearing about it. PM me on that please.
RL
Other rides:
Pictures:
6L Shootout Report:
post #13 of 15 (permalink) Old 01-29-2006, 11:15 AM
FINE69's Avatar
RL
I too would like to hear if anyone makes a kit to re-route the CCV out of the intercooler.
2009 F350 CCLB Larry-at, 6.4, all the toys....
FINE69 is offline
post #14 of 15 (permalink) Old 01-29-2006, 12:35 PM Thread Starter
RL
These all sound like great ideas. If it fixes the problem, great! My concern with modifying the boots and or clamps is it only masking the real problem. Bad turbo, producing too much boost? What will that do to my warranty if it blows the turbo, motor, or homogenator valve?
2004 6.0 4x4 CC LB
Edge 4.5" Lift Bilstein 5100's w/ BFG 315's
Bullet EGR Cooler
post #15 of 15 (permalink) Old 01-29-2006, 01:03 PM
Boots should stay on whether you are running 20, 30 or 60 psi. Stock turbos put out ~30 psi if they are running good (some have seen 35-36 psi). Boots coming off means a bad clamp or CCV oil lubing up the connections.
RL
Other rides:
Pictures:
6L Shootout Report:
