turbo cough???? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-05-2006, 12:40 PM   #1 (permalink)
turbo cough????
I have noticed a lot of turbo cough (if thats what its called)lately, is this normal when you install sct programmer? It happens when I let of the throttle and sometimes it does it when I'm accelerating. Any suggestions?
[b]2004 F250 Lariat 6.0L
Torqueshift, 4x4, Supercab, Shortbox.
<font color="red">Yeah, It's Bringing Sexy Back
midnight2004 is offline
Old 11-05-2006, 12:46 PM   #2 (permalink)
Re: turbo cough????
First I would take out the program and see if the same issue happens stock.
"Trade in"
2003 F-250,Lariat loaded and sweet except the 6.0.
Ordered 3/28/07 took delivery 6/7/07
2007 new body GMC Sierra SLT 3500 SRW long bed, Duramax/Allison,Black,loaded and even sweeter and more dependable.
toshiba is offline
Old 11-05-2006, 12:51 PM   #3 (permalink)
Re: turbo cough????
It does not do it stock. I'm just wondering if all programs normally do that. I also noticed an oil mist on top of the motor near where the downpipe connects to the turbo. I have heard of the turbos failing would this be a sign that mine is starting to go? And the additional fuel is too much for the turbo?
Old 11-05-2006, 02:13 PM   #4 (permalink)
Re: turbo cough????
do you have a diagnositic capabilities with your program if so run it and see if you get any dtc codes.
madams000 is offline
Old 11-05-2006, 02:29 PM   #5 (permalink)
Re: turbo cough????
I'm not throwing any codes.
Old 11-05-2006, 07:25 PM   #6 (permalink)
Re: turbo cough????
Turbo cough or turbo fart? Know what turbo farts are?
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures: http://community.webshots.com/user/ralphinnj
6L Shootout Report:
http://www.thedieselstop.com/downloa...toutReport.pdf
ralphinnj is offline
Old 11-05-2006, 07:58 PM   #7 (permalink)
Re: turbo cough????
I would have to say that is NOT normal with programs and everything working properly.
But you could be having turbo issues and with the timing and fuel change causing the problems.
At one time I was running a higher level and it eventually cause a #4 injector code when I changed to level #2 no more codes.
Since then I had #4 injector replaced May 06 and the Turbo replaced Oct 06 and I`ve kept the Edge on Level #2 runs and just fine now.
I would clean the area and try to track down where the oil is comming from,it could be comming from the steel bradded line that feeds oil to the turbo from the top of the engine next to the oil filter left side.
The code could be a hard code only and not show up with your scanner,that happen with my Turbo it showed up on my Edge Att. for a few minutes but dissapeared and then showed "no trouble codes found",but it was still in a hard code which is only detected when Ford checks it out.
"Trade in"
toshiba is offline
Old 11-07-2006, 09:01 AM   #8 (permalink)
Re: turbo cough????
funny this should be in here my truck does the same thing with the SCT.
Dan
'04 F-250 CC Lariat White w/silver 6.0 PSD 5 spd auto, 4X2, 3.73LSD, Straight piped SCT EXCALIBRATOR 2 TRIPLE A PILLAR AUTOMETER ULTRA LITE GUAGES BOOST,PYRO,TRANS ZOODAD*Silver Star Bulbs*
<font color="blue">Truck Pic's
triplethreat4597 is offline
Old 11-08-2006, 11:53 AM   #9 (permalink)
Re: turbo cough????
mine does it too. Sounds like a waste gated turbo. I only experiance it under a hard excelleration in the extreme program. probably building too much boost?
2004 f350 harley edition 4x4 crew cab
torque shift trans
banks monster exhaust
and a few other things to hop it up
jeepmoma is offline
Old 11-08-2006, 09:48 PM   #10 (permalink)
Re: turbo cough????
If it is turbo fart you guys are talking about, that is a well know phenomena. When you let off the accelrator after WOT, the high pressure air reverses through the turbo. What you hear is the air passing through your intake.
Ralph
Other rides:
6L Shootout Report:
Old 11-09-2006, 08:39 AM   #11 (permalink)
Re: turbo cough????
is it bad is it going to cause any problems
Old 11-10-2006, 06:37 AM   #12 (permalink)
Re: turbo cough????
It does not appear to cause any harm. Atleast no one has posted that there is a problem. Just a new sound.
Ralph
Other rides:
6L Shootout Report:
