also the veins on the 6.0 turbo are notorious for sticking if you know a friend with the right scanner they can check it for you if not, if it is still under 100,000 mile warrenty take it to a dealer,they can check it for you also ask them aboust the newest updat they have if turbo is ok the new update should help you out.I gotta good friend that is a ford master tech i called him and he said the biggest thing about the new update is with the ficm (helps save the injectors)but as long as you have no major deffects with something else this update should fix your problem
03 f-250 6.0 custom tunes sct
2 trips to the dealer ship to fix the same problem
got tired of wasted trips
fixed it my self ARP headstuds, EGR blockoff plate and guess what (no more problem !!!)
all work done by me
