Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 11-30-2004, 09:02 AM   #1 (permalink)
turbo lifesaver users
I was just about to buy a turbo lifesaver and I have a few questions to those who have one. I was thinking of getting the extended run time one. The question I have is that I heard it was not good to idle these trucks for longer then 15 minutes because of wet stacking. Is this true? Also, how many of you spent the extra 10 dollars for the extended time. I don't think that it is unreasonable for the extra 10 dollars. I emailed them and they told me that it would be the same as the 15 minute one, just with extended times up to 250 minutes.
2004 F-350 Lariat supercab 8ft bed
6.0 w/ Torqshift
Dark Shadow Grey w/ Black Accent
3.73 Limited slip
ESOF, Power rear sliding window, FX4 package
Tele/HTD/lighted mirrors
Pioneer AVIC-N3 navagation/ roof lights
Adjustable accel/brake pedal
Reverse sensors/ heated seats
polished cab steps
MFD 02/04
ISSPRO Guages (Boost, EGT, and Trans Temp)
Diesel Turbo Lifesaver
Sirius Satellite Radio
XM Radio
XM Navtraffic
2004fx4 is offline
Old 11-30-2004, 09:38 AM   #2 (permalink)
Re: turbo lifesaver users
dont know much about the long run time ones,I have the bully dog one set on the 3 min setting and my temps always get back down to about 325 before it shuts down, and from what i have been told that is good enough,I sat and let it idle for 10mis once just to see how low the temps would drop and after ten mins it only dropped about 50more degress.just my experinces,again I am no expert on this stuff
Jared
2003 F250 LB crew cab,4inch revtek lift,bilstien shocks,315/75/16 procomp at's on weld wheels.SCT from inovative AFE stage 2 4 inch bully dog exhuast isso gagues and turbo timer.
Jacack is offline
Old 11-30-2004, 09:43 AM   #3 (permalink)
FamilyRide's Avatar
If you have a need to let it idle more than 2-3 minutes it seems to me you need something else, like an AIC.
If you have your A/C on it won't cool off as quick or as much but < 400* is plenty cool to shut down which should be 30-60 seconds unless it after an realy hard run and A/C is still on. I kick the A/C off and idle it up to about 1000-1200 RPM and it drops temp quickly.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 11-30-2004, 12:15 PM   #4 (permalink)
I run the isspro timer. that way you don't have to worry about how long it runs, it just runs till it hits the temp I set it at. consider one of those, there nice.
2003 7.3 Bone stock CC 4x4
smcdonn is offline
Old 11-30-2004, 12:36 PM   #5 (permalink)
David Murphy's Avatar
If you have any questions on the ISSPRO TTM (Turbo Temp Monitor) give me a call. I'll be happy to discuss it.
David Murphy
www.DieselManor.com
info@DieselManor.com
Hours: Mon-Fri 8am-5pm EST
Telephone: 603-497-2281 ------- Taking the Mystery out of Diesel Performance™
PRODUCT LINE: MBRP Exhaust Systems, aFe, Volant, S&B Intake Systems, Worlds Largest Distributor of ISSPRO EV Gauges, ART Cryo/Slotted Rotors, DiPricol OPTIX, Autometer Performance Gauges, Superchips, Edge Products, CFM+, Vulcan Performance, Mag-Hytec, Stanadyne, and more... - Please call us at 603-497-2281 for technical information or special pricing. --- DieselManor Guaranteed Pricing Policy ---FREE SHIPPING---
24/7/365 Secure Shopping Cart
David Murphy is offline
Old 11-30-2004, 12:53 PM   #6 (permalink)
I have a Turbo Lifesaver in both my 96 and 04. The units are great and work as advertised. Both are extended run time and I think that was a waste of money actually. Have never run either truck for more than about 15 or 20 minutes. I guess theoretically, you could run your A/C while you were eating lunch and keep the pets cool in the summer. Anyway, I think they work, so far have been reliable, and help extend the life of the turbo charger.
96 F-250 7.3 L PSD, 4x4. 6in Super Lift with biggg tires. 210K and going strong.
2004 F-350 6L 4x4, CC, DRW, 4.10 LS rear, ESOF, Westin Chrome & SS Brush Guard, Reese 16K hitch in bed, Fumoto valve, Air Lift airbags on the rear. NEXT: A winch for the front!!
OIF 03-04 and 05-06. Keep the troops in your prayers. They are doing a great job. HOOAH!
JimmyRice is offline
Old 12-02-2004, 12:29 AM   #7 (permalink)
I have one and it also works as advertised. Got the extended run time one. Normally one to three minutes are all that is used. However, living in Southern California with the Mojave desert near by, I find almost any trip to the river in the summer or to Nevada, Arizona, New Mexico, Texas etc. and rest stops it is great to set it up for maybe 30 minutes, leaving the truck locked with the air on. Both me and my wife can leave for a potty break etc. without worring about it getting stolen, cool inside when we return, and in 100 degree plus temp, the engine gets nowhere near wet stacking.
We don't have pets but for those who do, it is obvious the usefullness. Anyway, even if it is seldom used, the extended run time is handy.
Dennis
2002 PSD , Auto, 4X4, Crew Cab Lariet, White, Camper Package, Leather, dual alternators, line-X bed liner, Limited slip dif.
Custom programmed Super Chip by Performance Associates, San Dimas, CA.,
BTS transmission upgrade and V10 trans cooler, AFE air filter assembly with ProGuard 7 air filter, Banks 3.5" down tube, Autometer Guages on A pillar, Pyro pre turbo, Spintech Muffler, BF Goodrich T/A KO 295/75/16 tires, Edge 2" spring pack. Rear wheel dyno (Clayton) horsepower = 265 at Southern California get together at Sunrise Ford 2-09-03. So far- Best Vehicle I Have Ever Owned. Love this truck
Member: SoCAPS Southern California Powerstrokes
BigGrump is offline
Old 12-02-2004, 01:39 AM   #8 (permalink)
My Photos: (26)
I have a 1 minute delay on my ignition with my remote start/alarm system. That is enough time to get the EGTs down to 400 by the time the truck shuts off.
2004 Superduty CC SB 4x4 PSD 6.0 Torqshift|ISSPRO Gauges www.dieselmanor.com |Edge 4.5 lift|315/70/17 BFGs|17x10s|Xtreme SCT Tune by www.InnovativeDiesel.com |4" Cat-Back straight pipe|John Wood Built 5R110 www.jwtt.com|ARP Headbolts|Modified AIRAID Cold-Air Intake|ZOODAD MOD |Pioneer W/XM Head Unit|Alpine Amp|10" MTX Sub|440 RWHP
http://photos.thedieselstop.com/show...=36994&thumb=1
VegasSuperDuty is offline
Old 12-02-2004, 03:00 AM   #9 (permalink)
WOW, a "turbo Lifesaver".......sounds TASTY!!! [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img] Sorry, I couldn't resist!!! [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/smirk.gif[/img]
<font color="blue">"Sic Semper Tyrannis" </font>
<font color="red"> 2003 King Ranch F-350 FX4 Crew Cab SRW SWB 6-OH!</font>
woodsracer is offline
Old 12-02-2004, 10:50 AM   #10 (permalink)
I had a question, does Ford service care about these cool down timers being installed? For example if you take it in for service do they complain about the modification? I wouldn’t think they would if they know anything about diesel engines they would know it's there to help, but just curious.
I want to install one on my truck also, who makes the best?
Has anyone used the BD Cool Down Timer?
2005 F-450 CC 6.0 auto two wheel drive
DEBramwell is offline
» Sponsor Links
»Garage Storage and Cabinets
