Van Aaken - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 07-18-2006, 03:30 AM Thread Starter
Van Aaken
Goin' to buy a chip to increase fuel economy and better towing performance as my warranty is about to expire. Considered the Van Aaken as easy to install, just plug'n'play and good results on the performance report here on TDS. Furthermore, it's significantly cheaper than the Edge. [img]/ubbthreads/images/graemlins/laugh.gif[/img] Does it come with the switch? Is there anything to be concerned about?
Jim
2009 F250 PSD 4x4 CC LB KR
2007 Suburban LT3
2007 Yukon XL Denali
2005 F250 PSD 4x4 CC LB KR
JimJoe is offline
post #2 of 19 (permalink) Old 07-18-2006, 07:23 AM
Jassman's Avatar
Re: Van Aaken
I believe Mark Craig sells these, and will be able to properly comment on these modules. I believe in regarding to the last round up, it faired real well for the dollars involved. Good luck. Jeff
2015 F350 LWB CC 3.55 Platinum on order
2012 F150 FX4 w appearance package
2011 F350 LWB CC 3.55's GPS Lariat. my truck
2010 F150 FX4 5.4 3.73's
2008 F350 LWB CC 6.4 dually. 3.73's
2007 F350 LWB CC 6.0 Dually, 4:10, ID SCT tunes Xtreme race, Xtreme street, and tow w/agressive brake, MBRP Turbo back cool duals AFE Mega 2 ..
Jassman is offline
post #3 of 19 (permalink) Old 07-18-2006, 04:46 PM Thread Starter
Re: Van Aaken
We'll await his comments. Can you switch between off, 50% and 100% while driving?
Jim
2007 Suburban LT3
JimJoe is offline
post #4 of 19 (permalink) Old 07-19-2006, 03:02 PM
Re: Van Aaken
I have the Van Aken module - and love it. Had the Edge Juice with Attitude before. Also have a pre-turbo EGT, 4" cat back exhaust and AFE pro guard 7 intake.
To answer your question - yes - you can switch on the fly between HP levels in the cab. ( 0HP, ~+70HP, ~+100HP )
rmathews is offline
post #5 of 19 (permalink) Old 07-19-2006, 03:09 PM Thread Starter
Re: Van Aaken
Just ordered it. darth_intel, do you see any MPG increase when driving "normally"?
Jim
2007 Suburban LT3
JimJoe is offline
post #6 of 19 (permalink) Old 07-19-2006, 10:16 PM
Re: Van Aaken
I get 24 MPG highway in the +70HP mode
Towing 5,000 LBS I get 18 MPG
Towing 14,000 LBS toy hauler I get 10 MPG.
I experienced 2-3 MPG with all the changes I made.
rmathews is offline
post #7 of 19 (permalink) Old 08-01-2006, 02:03 PM Thread Starter
Re: Van Aaken
darth_intel,
what were your figures befre the mod?
Get 17 MPG average, no towing. Highway is about 21 MPG. Should receive the Aaken any day from now. Hope to se at least +1 MPG. Hope for +2.
Jim
2007 Suburban LT3
JimJoe is offline
post #8 of 19 (permalink) Old 08-01-2006, 04:49 PM
Jassman's Avatar
Re: Van Aaken
Do you notce a difference when switching from 70 to 100. Can you feel it by the seat of your pants. Do you have any 1/4 miles runs just for the heck of it. Thanks Jeff.
Jassman is offline
post #9 of 19 (permalink) Old 08-13-2006, 12:09 PM Thread Starter
Re: Van Aaken
You are absolutely sure? I do not want to risk my engine on this. Thanks.
Jim
2007 Suburban LT3
JimJoe is offline
post #10 of 19 (permalink) Old 08-14-2006, 01:38 PM
Re: Van Aaken
JimJoe,
Yes it is switchable on the fly. Just don't ever have an engine all the way to the floor and make any switching changes. If you have any questions let us know.
Mark @ DPPI
Mark Craig is offline
post #11 of 19 (permalink) Old 08-14-2006, 02:59 PM Thread Starter
Re: Van Aaken
Yep, there is one thing I asken in another thread. The wire for the switch runs through a section of strange metal wires just after the battery. I wonder whether these wires get hot or may otherwise damage the cable.
Jim
2007 Suburban LT3
JimJoe is offline
post #12 of 19 (permalink) Old 08-15-2006, 10:32 AM
Re: Van Aaken
JimJoe,
Not exactly sure what you are asking about but you can route the switch wire thru the firewall anywhere you'd like to if you want to avoid that area to be sure.
Mark @ DPPI
post #13 of 19 (permalink) Old 08-16-2006, 02:32 PM Thread Starter
Re: Van Aaken
Look at here. I marked the strange wires in red. You see the cable running straight through them.
Another one: What are the wires here marked in yellow?
Jim
2007 Suburban LT3
JimJoe is offline
post #14 of 19 (permalink) Old 08-16-2006, 03:32 PM
FamilyRide's Avatar
Re: Van Aaken
The ones in yellow look like the customer option wires. ust some wire pre-run through the firewall to use. You'll find the other end of them on the other side of the firewall.
2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, bubba lights and newly added so called bullet proofing, including PMax turbo.
FamilyRide is offline
post #15 of 19 (permalink) Old 08-16-2006, 03:53 PM
Re: Van Aaken
Correct me if I am wrong, however, those steel lines you see are the brake lines [img]/ubbthreads/images/graemlins/smile.gif[/img]
2007 F250 PSD Lariat 4x4 Crew Cab Build Date 08/06
ATVwire.com -->
Forums, Create FREE Blogs, Create FREE Galleries
compindustries is offline
