If you're running a stock truck you're not going to see a lowering of EGTs that would justify the expense of a water/meth system. The stock IC does the job perfectly fine.
Adding methanol is going INCREASE power. In stock configuration, that is a bad idea. I think it makes much more sense to stud your engine before adding a water/meth system.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Gun Control means using both hands.
