What does defueling mean? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 01-13-2004, 07:35 PM Thread Starter
I have been reading posts with the term defueling between shifts when chips are installed. What exactly does this mean? Thanks.....
2004 F-350 4x4 6.0 auto SRW Crewcab Shortbed Lariat 3.73 Limited Slip, Black w/Tan leather Moonroof, TTT Mirrors, adj ped,6-cd, rev. sensors, heated seats, keyless entry, power rear slider, build date 11/10/03 DPPI dual exhaust, sprayliner, roll-n-lock, Replacement for 2003 buyback 2003 Cobra Conv.10th Anniv. Black/Black
FASTFRANK is offline
post #2 of 9 (permalink) Old 01-13-2004, 08:13 PM
GWA
Re: What does defueling mean?
Just what it says, the fuel is cut back during the shift, which cuts power a bit so as not to overstress the tranny. Usually you won't even feel it under these circumstances. Another occasion for defueling would be if the exhaust temps(EGT) go too high, causing it to defuel. Then you would feel the power flattening out somewhat. Hope this helps!
'03.25 F-250 SC SWB 2WD 6.0w/TorqShift, Sport Pkge., Sonic Blue, plus-
16x8 Eagle alloy wheels
Snugtop XV and Bedrug
DPPI turbo-back 4" "sound system" w/cat
The Heartbreak of "The Heartbeat"!
GWA is offline
post #3 of 9 (permalink) Old 01-14-2004, 09:14 AM
FASTFRANK,
GWA is correct and it also will pull back fuel when you exceed pre set EGT on the Attiude Monitor, if you get the Edge product, to reduce fueling when you exceed to max EGT level you asked it to watch for. In other words you get the Edge and Attitude, you pre set that you want the max EGT to be 1300 degrees, if the Attitude sees that or more as you climb Mt. Everest it will slowly pull back fuel and set off an audible alarm to reduce the fuel to reduce the EGT level you pre set. Basically it's EGT proof, we sell a lot of them because folks just want to set it and forget it! Call me if you have any questions etc.
Mark @ DPPI
Mark Craig is offline
post #4 of 9 (permalink) Old 01-14-2004, 10:24 AM
Ain't it what you do to deplane before detakeoff?
2005 F-250 King Ranch 3.73LS CrewCab SWB 4WD Viper Remote Start/Alarm - Banks Cat-Back - SCT from the Froggy guy.
wellstroked is offline
post #5 of 9 (permalink) Old 01-15-2004, 07:26 AM
Wellstroked,
Sounds like you worked with Ricardo Montaban on Fantasy Island?????
Mark @ DPPI
post #6 of 9 (permalink) Old 01-15-2004, 08:18 PM
GWA
Yeah, but he came up "short" of the requirements. Eh, Tattoo?
GWA is offline
post #7 of 9 (permalink) Old 01-16-2004, 08:06 AM
GWA,
OOOH that was a very "short" thing to say to a nuce guy like me!!!!!
Mark @ DPPI
post #8 of 9 (permalink) Old 03-20-2017, 09:03 AM
Opy
Can a defueling setting cause excessive blue smoke after heavy acceleration when leveling off speed?
Opy is offline
post #9 of 9 (permalink) Old 03-20-2017, 05:02 PM
79jasper's Avatar
No.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
