Where to put oil temp sender? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 09-21-2007, 07:04 PM   #1 (permalink)
Hi everybody,
The last gauge I have left to install is the oil temp. I have no idea where to put it. I read about putting it in the filter cap. Would that give an accurate reading? I would like as many suggestions as I can get and am interested in all my options. 04 f250 6.0
Thanks.
04 F250 Crew Cab long bed 6.0, 5.5" lift, 35' toyo, Airaid intake, Banks 4" turbo back w/cat, Edge Juice w/attitude, Autometer gauges (coolant, oil, trans Temp),Pulling 2006 30' Ragen 5th wheel toyhauler 10,000 lbs loaded with quads. I run stock tune while towing.
chrismary is offline
Old 09-21-2007, 10:23 PM   #2 (permalink)
re: Where to put oil temp sender?
I had mine in the filter cap. ACtually had oil pressure sender there too. Just ran a T on top of the cap.
The billet caps on the market make this really easy. If you drill/tap the stock one...you'll be shocked at how thin it is.
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
Old 09-23-2007, 10:57 PM   #3 (permalink)
Thanks UnB, anyboady else have another place to put it? Is the oil pan the most accurate? Help me out.
Old 09-24-2007, 11:00 PM   #4 (permalink)
weasel79's Avatar
I would t into the stock oil temp sensor which is on top of the oil cooler.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe, tire clearance and guage photos
weasel79 is offline
Old 07-29-2010, 05:46 PM   #5 (permalink)
What is needed to do this besides a t fitting? Do you need an adapter too? What size?
Thanks!
2005 F350 4x4 crew cab short bed srw. Lariat package. MBRP 4" turbo back exhaust.
dits145 is offline
Old 07-29-2010, 07:26 PM   #6 (permalink)
paintingman's Avatar
I have mine in the billet cap with oil by-pass filter i may move it to the sending unit location i was going to get a new sending unit to get the thread size and the tee and put it together before hand. it seem to work in the cap though there's only 5 degrees difference between EOT and ECT.
_________________________
2004 F250 6.0 PSD every day work truck
Jotto desk / laptop / printer for giving estimates
3000 watt inverter keeps drill batteries charged
4" tubo back MBRP cool duals
CFM+ intake elbow / Airaid cold air intake
SCT X3 from innovative diesel
Coolant Filter / Amsoil by-pass system
ATS Intercooler
Fluidampr / 200 amp alternator
ARP head bolts / Black onyx head gaskets
185cc Injectors 70hp+ / stock turbo
stage 1 fuel lines / cross over with fixed orifice
58 volt FIMC mod from swamps diesel
Airdog 2 with in tank fuel module upgrade Mag-Hytec Diff. and trans. covers
Aluminum degas tank
paintingman is offline
Old 09-30-2010, 01:32 PM   #7 (permalink)
I tapped my OEM filter cap.
[IMG][/IMG]
[IMG][/IMG]
I put a brass nut on the underside of the cap. I still have about 1/2" clearance before the spring is touched. The only problem I seem to have right now is low oil temps, about 155. I am trying to sort this out. I will try to swop the ECT send with the EOT sender to see if there is any change. Anybody have any suggestions or has this happen to you and you fixed it?
2007 F250 6.0L PSD Lariat 4X4 - Dieselsite Coolant bypass Filtation - Bilstein Shocks - Rough Country Duel Steering Stabilizer - Fumoto Oil Drain Valve - HFCM Water Separator Drain Plug Upgrade - Blue fuel pressure upgrade spring - studded - Gauges, Fuel Pressure, EOT, ECT, EGT
headviking is offline
Old 10-02-2010, 11:25 PM   #8 (permalink)
Unbrocken
How are you temp reading from the oil filter cap. What temps are you getting? Do you have a picture of the installed sender?
Old 10-03-2010, 09:09 PM   #9 (permalink)
mwilbur516's Avatar
Headviking, the reason you're getting low oil temp readings is because the temp sender is installed after the oil cooler. You need it somewhere in the system before the oil gets cooled. Your concern is how hot the oil is before the cooler. The best place in my opinion is at the oil pan.
mwilbur516 is offline
Old 10-10-2010, 10:44 AM   #10 (permalink)
You have a 5* difference between EOT and ECT? Using your Oil filter cap. My in registering about 15 below ECT, reading from the filter cap, why?
Old 10-10-2010, 12:11 PM   #11 (permalink)
My EOT is 5 to 10 degrees cooler ECT it could be because it's after the cooler and it's a new cooler and there no hills to climb here all flat roads.
The aluminum cap may hold the heat different than the plastic cap
ATS Intercooler
Aluminum degas tank
Old 10-10-2010, 12:48 PM   #12 (permalink)
Paintingman, That makes sense. Just a quick question. after the oil is cooled in the oil cooler. Wher next does the oil go? In this same system, when do the oil come from directly before it's filtered.?
Old 10-10-2010, 01:35 PM   #13 (permalink)
This diagram shows oil flow
Page 22: Lubrication System
ATS Intercooler
Aluminum degas tank
