Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Ok this is where Im at got white smoke,so I'm going to take care of all the problem stuff. If I can. Tell me if I've forgot anything.
Arp studs w/ford gaskets--have heads checked for flat,magna flux,may penentrant test. valve job,O-rings for injectors and glow plugs.Do I need new cups?
IPR--high flow coolant filter w/manifold (full flow filter before oil cooler)
IPR--gen2 egr delete w/ up pipe.
IPR--updated standpipe andrail plug kit
stc HPOP fitting update
updated turbo oil drain tube
updated turbo oil feed line
updated HFCM drain plug What do I need to clean?
Fumato oil drain plug--already have block drains
Ford thermostat
radiator hoses/ heater hoses/hoses to degass bottle
Turbo cleaning kit
Oil filter/ Rottella T-6 Arch oil AR 9100
fuel filters arch oil AR6200
almost forgot I need a fuel tank ringnut and gasket (leaking lequid gold)
Maybe I missed it but replace the EGR cooler with an upgraded cooler?
This shouldnt set you back over about 5-6 grand unless you are planning to perform the work yourself. Good Luck
2004 F250 Crew Cab King Ranch Lariat FX4 Saddle Leather 6.0 L FUMOTO Valve
AIRAID 4" straight No CAT No MUFF
Nitto Terra Grapplers All Terrain LT285/75R16 10 PR Everything else pretty much stock
NEW Ranchos installed 8/15/2010
WORK IN PROGRESS - R&R EGR COOLER, OIL COOLER, THERMOSTAT, TURBO BOLTS, GASKETS, ORINGS, and adding a COOLANT FILTER WITH NEW COOLANT AND FLUSH
Left the oil cooler out on purpose. Been fighting a low coolant problem,that I havent been able to correct. Deltas are still ok with old cooler. Have flushed, changed thermostats twice, changed temp sensor, new degass bottle cap, changed water pump and belts. So I may flush again, when filter is installed. I've had truck a year and wondering if something has been added to stop a leak.Can put cardboard in front of radiator and delta is only 2 to 4 degrees. Temps run about 180 now.
The weak points of the 6.0L are the EGR cooler and oil cooler. Those things are what cause the majority of all other problem. Why not fix the weak links while you have all the other stuff out of the way. It is much more simple to do all this work while the cab is off.
Not doing cab off. Notice Im putting a coolant filter before oil cooler. I belive the problem is the coolant flashes off and has particulate fall out then that coolant goes to the small passages of the oil cooler and stoppes up.Im doing a egr delete and full flow filter (not a bypass) before the oil cooler. the updated oil cooler is just a replacement heat exchanger. not an improved design.
Go to IPR diesel's website and look at gen2 EGR delete , coolant manifold and full flow filter.
