Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I want to add a box to my truck, but I am more concerned about my tranny than the high horsepower setting. I dont want to go the "tuner" route as I think the box type is better. I know a lot of guys here have the Edge and Quad, but in the reading I have done it seems the Banks Six Gun might be the safest on the tranny. What do you guys think. Help me out.
__________________ 1997 F350 CC4X4 120K superclean truck Beans 6 pos chip! IDM mod(it works!) Pyro, Boost and Trans Autometers over mirror. 4" straight pipe! 285/65X18's Nittos. Ford V-10 trans cooler, Tymar Intake, 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline in front of a BTS. WOP QSSB turbo! 1997 F350 XLT 4dr 125K 5" Pipe no muf and no kitty (totaled). 04/04 F350 EX Cab LWB "Leveled" Lariat FX4 Limited slip. BFG's 295/75R16. 4" pipe from back of kitty exiting in front of rear wheel. Autometer Pyro and Boost guages 65K. 422hp and 772tq (SOLD) 96 F250 powerstroke extended cab. Original E40D 132K Wood hauling machine. 10k MOD. Autometer Pyro and Boost gauges. Gutted Cat. Sold.
1966 Mustang "mostly restored" replaced by 2009 Dodge Chalenger! My Youtube vid. http://www.youtube.com/watch?v=fdXy-bV6Zks
I think it's all in how you run them. Once the tranny is shifting right then it's really a matter of how much abuse you put into it. Any of the boxes on a high setting are going to be bad, but I do kinda think you are right in saying the banks. I think they make there products with alittle more safty and alil less power. Anyway, like i said, a low power settin on the boxes I think should be pretty much the same, now you need to control to keep it turned down
04' F-350, Crew Cab, King Ranch, Dually, LOADED.. DPPI Turbo Back, gauges,SCT from kermit, air raid, coolant filter, amsoil bypass
I spoke to a VERY knowledgeable transmission source about how much power can be added without significant damage to the tranny. His remarks were that about any of the boxes up to around 100hp can be used by themselves, if you use your head. However, if you are racing your truck, towing overweight, stacking boxes/tuners, putting a lift & big tires on, etc, then any and all will damage the tranny to some degree or another. Bottom line is, it's basically up to you whether there is a safe box or not.
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
Thanks for the replies. I mostly want the box for drivability and fuel economy as a second. The Edge box is what I lean twards most because of the low boost fueling adjustments. I can't see where the Banks has that, only different settings.
IMO if you want drivability and fuel economy, leave it stock and drive it conservativly.
SC is the only one that tunes the tranny, so the next step would be a SCT wiht only a tranny tune to bump the line pressure a bit to keep the tranny alive longer. Maybe a mild tune if you actualy do want a little more get up and go.
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
pretty much all the boxes and tuners on the market are adjustable from low economy/tow tunes to extreme/race tunes, and everywhere in the middle. and for the most part, any box in a 50-60hp tune is going to shift fine. something like the edge/attitude is nice because of the low boost fuel, so power comes on pretty early. some of the other tuners and high hp boxes like the quad 160, power comes on like a freight train, weak in low rpms but around 2500rpms or so takes off like a missle. i havent tried the edge/attitude in lower settings, but it shifts absolutely perfect in 5/5. the quad 160 shifted flawlessly as well...
Does anyone know if another company has a low boost fuling option like Edge?
Quadzilla has some tunes that fuel really early, but for fuel economy that is not really a good thing. The Quadzilla 75hp tune in the 160 module adds 100 miles to a tank of fuel when compared to stock on my truck.
Since I have removed my Quadzilla my fuel milage has dropped noticably. When I kept in in the lower setting I could see a 1-2 MPG gain over stock. Ford is forced to tune these trucks for emmissions. not fuel milage. Teamroper get better fuel milage with his original progamed 2003 dually then I get with my flashed SRW 2004.
2004 Harley Davidson F-250 C/C
SLAPS (St. Louis Area Powerstrokes)member.
to become a member go to www.stlouisareapowerstrokes.com
That is a lot of miles. I would like something like that, that would make it a little more fun to drive and when crusing it would improve my miledge.
I was talking with a guy that works at the Louisville truck plant, and he said he was watching the trucks being tested when they first came out. They run the piss out of them on a dyno, and at a certain rpm, the tranny would give out. They flashed the computer to keep the revs down below critical failure and put the truck to market. Don't know if they've fixed the problem, or just keep the engines from hitting that level of rpm's. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'96 250,Ext.Cab, XLT Lariat,PSD,ATS Stage 3 E40D,NAW4,4.10s,4X4,shimmed reg., Western Diesel down pipe, V10 tranny cooler,
TS 6 pos chip, 4 air bags, 315/75 Cooper tires, custom open air intake, 10 X 16 aluminum wheels, Baby Swamps,
