who thinks a coolant filter would fix a lot of the 6.0 issues??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 09-14-2007, 09:33 AM   #1 (permalink)
I recently read that the flawed design of the egr and cooler is causing a majority of the 6.0 reliability issues. Coolant loss issues are being caused by the egr cooler failing, and flash evaporating coolant, which is mis diagnosed as head gaskets. soooo on to my question.
would installing a coolant filter keep the egr cooler from blowing up? from what i read, if you have proper coolant flow, then it will keep the egr cooler from clogging.
im still way within warranty, and have no issues with my 06, but for 120 bucks for a screw in coolant filter, it seems like a good idea...
2006 f-250 q-cab, lariat, 4wd medium wedgewood blue and arizona baige, bfg 305's
55k miles
1982 jeep scrambler
2001 bmw 525i 90k miles
ncmallard78 is offline
Old 09-14-2007, 12:07 PM   #2 (permalink)
Re: who thinks a coolant filter would fix a lot of the 6.0 issues???
Lots of guys are using them. I haven't yet.
OMCUSNR is offline
Old 09-14-2007, 01:47 PM   #3 (permalink)
My Photos: (38)
I can't specifically advocate a coolant filter system - since it is most decidedly an aftermarket component. As such, if it failed and cause a loss of coolant which blows up your motor, you'd be screwed.
From what I've seen, a good percentage of EGR cooler failures are caused by insufficient cooant flow through the oil cooler. There are several small passages that can get stopped up. Filtering out these particulates would seem to reduce the chances of packing up the oil cooler.
What I can say is that I've heard the VT-365 engine (International's version of the 6.0L) has a boss on the front cover for a coolant filter system.
And, if I owned one, I would put a quality coolant filter system on. Possibly even installing International's front cover and use their setup. Be aware, I haven't researched this swap, so I don't know what would be involved, nor the effectiveness versus a generic aftermarket system.
What sig?
GregH is offline
Old 09-14-2007, 02:40 PM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: GregH</div><div class="ubbcode-body">I can't specifically advocate a coolant filter system - since it is most decidedly an aftermarket component. As such, if it failed and cause a loss of coolant which blows up your motor, you'd be screwed.
</div></div>Well International must think the Coolant filter is a answer to some of these issues.Since early 04 we Install them when doing Uptime proceedures on the VT.And yes the front cover has acess plugs where we tap feed and return to the filter head.Very simple.Obviously the cover would fit on a Ford version.But I think you would run into possible issues with accesory mounts but I am not sure.As far as Filter type it is a Basic coolant filter.NO pre-charge since Factory fill on ALL International Engines is ELC coolant.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline
Old 09-14-2007, 04:55 PM   #5 (permalink)
im thinking about getting one of these...
http://www.dieselsite.com/index.asp?...ROD&ProdID=324
look at all the crap it filters. seems like running a filter to keep this tempermental egr cooler running makes good sense.
what does a new egr and oil cooler cost????
55k miles
1982 jeep scrambler
Old 09-14-2007, 05:13 PM   #6 (permalink)
My Photos: (38)
Don't forget that these pictures can be misleading. If the cooling system on your truck is clean, then the filter won't catch anything....
What sig?
GregH is offline
Old 09-14-2007, 05:14 PM   #7 (permalink)
My Photos: (38)
Oh, and an EGR cooler and oil cooler replacement costs upwards of $2000, if you had to pay for it yourself...
What sig?
GregH is offline
Old 09-14-2007, 05:18 PM   #8 (permalink)
teamroper60's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: GregH</div><div class="ubbcode-body">Don't forget that these pictures can be misleading. If the cooling system on your truck is clean, then the filter won't catch anything....</div></div>
Greg,
There is the deal.... If the cooling system is clean. Based on what I am reading and hearing, the cooling system is not clean when it comes out of the factory.... You would presume a good flushing would clean it up, but who knows......
Another related question for you and Grounder (or any other tech):
What in your opinion would be the best way to flush the system prior to a refill??
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 09-14-2007, 06:01 PM   #9 (permalink)
My Photos: (38)
To be honest, we don't do many cooling system flushes here.
When I do a headgasket job, I pull the drain plugs on the sides of the block after the heads are off. This drains almost the entire block. The radiator, of course, has long since been drained since it's still on the body up in the air. I then just refill it when the truck is back together.
For oil cooler failures that cause an EGR cooler failure, I do the same thing. The thought is that the oil cooler has already caught the majority of the crud - the whole reason it failed.
For oil coolers that cause cross contamiation - that's another story. The truck gets multiple flushings with VC-1 (a soap from Ford). Between each flush, I drain the radiator and pull the left side block plug (it's easy to get to).
The reasoning for the inattention to the cooling system is simple. Ford doesn't pay much, if anything, for flushing the cooling system. And, from past experience, the above procedure seems to perform satisfactory. So far, I've never had to replace an oil cooler for packing up with crud more than once...
We haven't really ever serviced a cooling system on one of these trucks without being part of a cooling system repair - all we usually do is a drain and refill at 100,000 miles...
I would think that flushing the cooling system, or installing a filter would be a one-time thing. Seems to me the majority of the crud is in there from the factory - be it stop leak pellets, casting sand, or whatever. The engine shouldn't manufacture crud during normal service...
What sig?
GregH is offline
Old 09-14-2007, 08:12 PM   #10 (permalink)
bogg's Avatar
My Photos: (5)
Better safe than sorry as the line for head gaskets continues to grow at my local dealer. I am going in for a flush Tuesday morning. Should I consider upgrading the thermostat to 203 at this time? What are the benefits?
07(built 06/06) 6.0 Lariat/Moonroof/Camper Pkg/ FX4/DRW/5spd TS/13K GVWR/4.10LS/CC/LB/F350: Accufab Elbow/Mag-Hytec/AutoMeter Tripod(EGT/Trans/Diff)/PIE-Sirius-IPOD/Infinity Speakers/Zoodad/Fumoto/IH-HFCM/Precision Grill/Special Edition UT Weatherguard Crossbox/Coolant flush@25k/Coolant in-line Filter/MBRP 4" Duals/Coil-Rite 4160 Frontend My Truck Pics:
http://good-times.webshots.com/album...ost=good-times
bogg is offline
Old 09-15-2007, 12:34 AM   #11 (permalink)
I ran the coolant filter from Doug at http://www.gogodiesel.com
The first 2 filters I changed looked like I filled them up with sand then they slowly got cleaner as I changed them....by the 7th or so I would just get a few grains of sand out of them.
My reservoir was noticibly cleaner by the 3rd filter.
I won't run a truck again without one. The amount of casting sand left inside is incredible.
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
Old 09-15-2007, 12:16 PM   #12 (permalink)
ritschner's Avatar
Send a message via AIM to ritschner
I have run coolant filters on both of the 06's I have had. The first truck (the stolen one) after the degas bottle developed the nasty film of crud on the bottom. No more crud after the filter installation. The second truck got a coolant filter at less than 500 miles and after 24,000 miles has never gotten the crud build up in the degass bottle. In both cases the first filters clogged at less than 1000 miles and the second filters clogged in another 2000 miles. It is my opinion that a properly installed coolant filter system will benefit these trucks and eliminate some of the oil cooler and EGR cooler issues. It is also my belief that a majority of the head gasket issues may be misdiagnosed EGR cooler issues. But with out fleet testing or a large scale survey of trucks with coolant filters it would be hard to prove.
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB w/cat, Accufab, Edge Platinum/w Evo Trans Tune, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
Old 09-16-2007, 08:14 PM   #13 (permalink)
how hard is the install??? just bought one [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
55k miles
1982 jeep scrambler
Old 09-16-2007, 08:17 PM   #14 (permalink)
FTG-05's Avatar
My Photos: (25)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: ncmallard78</div><div class="ubbcode-body">how hard is the install??? just bought one [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img] </div></div>
It's extremely difficult, time-consuming and virtually impossible - if you start off dead drunk and only have a pair of broken plyers as tools.
Otherwise, it takes about 30 minutes. This is for the dieselsite.com version, which is what I have has installed in my PSD since it was 40 miles old.
Good luck.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
Old 09-16-2007, 08:59 PM   #15 (permalink)
What he said ^^^^
Super easy to install.
...coming soon...
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
