Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 07-07-2008, 12:18 PM   #1 (permalink)
Would putting bigger tires on really hurt my MPGs?
I always thought that I would put bigger tires on my truck when I got it. But I only wanted 35s or something like that, and maybe a 4" rancho lift.
Would adding these things really hurt my fuel mileage much?
getpower is offline
Old 07-07-2008, 12:34 PM   #2 (permalink)
Yep. Hard to say how much, but I would guess 1-2mpg will be the hit depending on how heavy the new set up is.
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures: http://community.webshots.com/user/ralphinnj
6L Shootout Report:
http://www.thedieselstop.com/downloa...toutReport.pdf
ralphinnj is offline
Old 07-07-2008, 04:42 PM   #3 (permalink)
It will hurt
I put on Toyo 35x12.50x17 M/T's and a 2.5" lift, and suffered. I lost 1.5 mpg city and 2.0 mpg highway. Others say they get great mileage with lift and bigger tires, but I don't see how. I drive pretty easy, and mileage is not good. I get around 13.6/15.0 consistently, used to get 15.0/17.5 with the stock 265/70/R17's.
2005 F-250 6.0L,FX4,CC,SB,Dark Shadow Grey,2" lift, 35x12.5R17 TOYO M/T's on stock wheels,Cab steps,TOFF Bedliner,Sirius,60w Infinity Reference Speakers,40w x 4 Alpine Amp,Access Rollup bedcover,ID SCT Extreme Street tune,RanchHand Legend replacement bumper,WetOkole seat covers
joerendon is offline
Old 07-07-2008, 05:59 PM   #4 (permalink)
Yes. A 4" will drop you about a solid 3m/g. Going higher will cause more loss.
Its physics at work. By lifting the truck you're doing two things that adversely affect economy. 1 - you're increasing the frontal area, which makes it that much harder to push down the road. 2 - you're increasing drag by allowing more air to flow under the truck where all that drag inducing stuff hangs out into the air stream.
The largest tires I'd consider would be 285's, and even these will increase rolling resistance at low speeds.
OMC
OMCUSNR is offline
Old 07-07-2008, 07:01 PM   #5 (permalink)
Supporting Member
my03psd's Avatar
I agree w/ OMC.I have 285s on my truck and haven't lost any mileage but I would go any bigger,just personal preferance.But I'm sure the bigger you go the worse it is.
03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,tint,Rhino lined,Sirius,Roll&Lock,strobes,Flaspaq,Prodigy brake controller,& HFCM plug upgrade
my03psd is offline
Old 07-08-2008, 02:44 PM   #6 (permalink)
Truck in sig, 15mpg highway unloaded, 12ish around town. Towing depends on the load. I've had as low as 9 and as high as 11.5. I don't know what it got before I put the lift and tires on. It has just over 15K on it right now.
07 CC LB FX4 TS 6.0 Oxford White, 4.5" DR lift, 315/70/17 BFG on 17x8 American Racing Mojave
Nubbs is offline
Old 07-10-2008, 02:30 AM   #7 (permalink)
hypersnyper694788's Avatar
i have a 6" lift and 37's and i got around 11-12 and i drive city and highway. Thats hand calculated not the in accurate mpg meeter in the truck. I recently added a 4" cat back i can tell a 15-20% gain which is good. But its totally worth the mpg loss to have my truck lifted i love it. Just do it
06' F250 CC SRW Lariat, 6" fabtech lift w/ bilstein 5100's, 20x10 polished eagle alloy 114's, 37x13.50x20 Nitto Mud Grapplers, 4" mbrp, 2 jl audio 10's
hypersnyper694788 is offline
Old 07-10-2008, 09:55 AM   #8 (permalink)
Yes... it will seriously hurt your mpg, and power. I run a 4" lift with 35x12.5x16r Goodyear wrangler tires and get 11mpg average with mostly highway. Programmer always set on extreme and a heavy foot doesnt help tho! Anyway, larger tires are sweet, but have their drawbacks. I believe you lose about 2.5% of your horsepower and torque for every inch your tires are larger than stock. However, the coolness factor is priceless haha !!
2003 F-250 XLT FX4 6.0l turbo diesel, sc shortbox, torqushift 5spd auto.
Procomp 4" lift, 315-75-16R Goodyear Wrangler tires on 16x10 American Eagle Wheels, Edge Evolution tuner, Airaid intake, Magnaflow performance 4" tubo back dual exhaust with 5" tips, WARN Premium manual locking hubs, Bushwacker fender flares, Smoked cab and 3rd brake light, Aftermarket headlights, tail lights and reverse lights, TomTom GO 920 Navigation system, Ford custom seat covers, Lund tonneau cover.
NBhunter80 is offline
Old 07-11-2008, 09:29 AM   #9 (permalink)
Just to clarify, the maximum power and torque of the engine doesn't change due to the tire size. The larger tires will have a greater mass moment of inertia, which makes it harder to get them spinning. They will most likely have a larger contact patch and thus more rolling resistance. They will also most likely be wider than the stock tires, have more aggressive tread, and stick out farther than the stock tires, causing more aerodynamic drag. And, since they are taller, the distance from the pavement to the center of the wheel is greater, resulting in less force pushing the vehicle forward. With all of these things added up, you will need to use more of the engines available power and torque to maintain the same vehicle speed and acceleration as before. I hope that wasn't too nerdy of a respons....
Nubbs is offline
Old 07-11-2008, 10:28 AM   #10 (permalink)
Yes, you are correct. By "losing hp and torque", I did not mean your engine hp will drop, but the felt force at the point where the wheels contact the pavement will be less due to greater lever arm. I meant that the hp and torque will be "wasted" in a sense (without going into Newton's laws and all that crap). That is what actually matters with respect to the force pushing your vehicle forward. Drag, resistance of the tires, and inertia of the wheels are also factors that increase the amount of power required to get the same acceleration as a similar truck with smaller tires and no lift. Anyway, as said before :Yes, larger tires and a lift will significantly impact your mpg.
Old 07-12-2008, 05:12 PM   #11 (permalink)
While I didn't go with a lift (tires fit without one) I did switch to 305/70R18 (35x12x18) tires and honestly didn't notice any drop in either power or fuel economy.
At some point in the future I am looking at putting a 2.5" leveling kit up front as well as 3" drop hangers in the rear (need to keep my load capacity) so I guess I will have to see what happens then.
Steve Urban
Semper Fi!
2007 F350, Lariat High Line, SRW, SC, LB, 4x4, 6.0/auto, FX4, Camper Pkg, HD alt, Red w/custom black two-tone, Buckstop bumpers F&R, Warn 16.5ti winch, Line-X, F550 coils, 305/70R18 ProComp XtremeMTs
2007 Apex9.5 truck camper
1973 Bronco (stock), wife's
1973 Bronco (HEAVILY modified), mine
2006 Mustang V6, Screaming Yellow, wife's
2006 F350, Amarillo, SRW, CC, 4x4, SB, 6.0/auto (traded)
2004 F350, SRW, CC, SB, Sport, 4x4, 6.0/auto (bought back by Ford)
SteveIn29 is offline
Old 07-12-2008, 11:46 PM   #12 (permalink)
Idaho Slim's Avatar
Lift and tires make mpg suffer,however you can mitigate that somewhat by chanigng gears.
I run 4.30 gears with 8 in lift & 37 toyo's. Driving normal, empty hwy = 16.2, city 13.8. Towinng heavy 10-11. towing light 12-13.
" I hate Rude behavior in a man, I wont tolerate it." Woodrow F. Call, Lonesome Dove.
2004 6.0 F250 CC, 8 in Fabtech, Fabtech Traction Bars, 40x13.5x17 ProComp XT's, Rancho RS9000XL's 4.30 Gears, DiProcol, Silverline 4" Turbo Back, WorkHorse Module.
2006 V-10, F350, 4x4, CC, SB, Auto, K&N Drop-In.
Idaho Slim is offline
Old 07-18-2008, 10:44 PM   #13 (permalink)
I went from about 20 mpg down to 13-15 when I put on the 40's..
2005 F350 Lariat
12.5" Fabtech lift w/dirt logic shocks, dual dirt logic stabalizers,40" Toyos on 20x12 DC1's, Amp power steps, AFE pro guard 7 &, AFE 4" straight pipe from the turbo back, ProComp traction bars, Mag hytec diff cover, SCT and Banks Bullet, Recon smoked LED tails, third brake light and mirror covers, ARP headstuds, DR adjustable trac bar, Harley headlights from Eagle eyes, HID's, and trainhorns....
supadupaj is offline
Old 08-02-2008, 04:17 PM   #14 (permalink)
Hay Idaho Slim, OT but you are running 40's with "just" a 8" lift? does it rub alot? or at all? how you like it? I want to go to 40's on my truck from the 37's I'm running now but I dont want to go to a 10" lift.
2004 F350 Harley CC 14.2@92mph
93 Dodge Stealth RT TT 8.81@166.7mph
95 3000gt VR-4 10.56@136mph
92 Dodge Stealth RT TT 10.69@133mph
95 Dodge Stealth RT TT 10.88@129mph
FastMatt is offline
