12 Volt Oil Pump - Diesel Forum - TheDieselStop.com
Old 04-13-2006, 08:45 PM   #1 (permalink)
12 Volt Oil Pump
I saw someone had posted a link to a 12 volt pump. I need to buy one to gather oil from the resturants and also to pump bio-diesel when needed. I found this one at Northern Tools. Is it worth the $$$
12 V Oil Pump
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2001 SC, SB, Auto, 3.73LS, PMT2, Ford AIC, Magneflow 4" Stainless Exhaust, Ford AIS Air Cleaner, 40K True Cool on Trans, Magnefine Filter on Trans, Purch. New 3/29/02 Schaeffers 15W40 engine oil. Royal Purple Trans and Rear Diff fluids.
1995 PSD SC, LB, E4OD, 4.10, 74K miles, BTS Transmission, Hayden 679 trans. cooler, Racor Primary fuel/water separator, Cyclops, Frantz Bypass Filter, Royal Purple Synthetic 75W140 Rear Diff, BD Downpipe, Gutted kitty. TS w/4Pos, Stock, Hi Idle, 60HP, 75HP, Western Diesel Turbo Brake III, Schaeffers Trans Fluid, and running B100 summer and B50 winter.
59 Vetteman is offline
Old 04-13-2006, 09:03 PM   #2 (permalink)
Re: 12 Volt Oil Pump
thats the same pump that I bought looks like it will work and it says will pump oil. haven't got it yet but keep you posted
1999 ford F250 PSD 7.3 lariat 4x2
AFI air cleaner
superchip programer
4" Exhaust
helwig sway bars front and back
Pilliar gauges
Now 2006 F350 DRW 6.0 Lariat 4x4
running 80% home brew bio
yadizio is offline
Old 04-13-2006, 10:45 PM   #3 (permalink)
I use a Shurflo 110 volt rated at 5 GPM to transfer from barrels to the processor. Today it took 30 minutes to transfer 36 gallons of 110 degree oil. 3 foot suction (height of 55 gallon drum) 3 foot lift (top of 50 gallon heater) Kind of wimpy, but it is paid for.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 04-14-2006, 12:48 AM   #4 (permalink)
Depends on what you want to do with it. I used to have one of those pumps to pump my biodiesel from the barrel, through a final polishing filter into the tank. The system pumped fine until the filter got a little particulate in it, then it stopped almost completely. The pump just doesn't put enough pressure out for some applications, so I used one of the 1" clear water pumps and the final filtration system is perfect now. However, if all you want to do is pump warm (or hot) oil, then that pump is well worth it, portability and power.
The fleet: 2002 F-250 XLT, 2003 F-350 XLT, and 2003 Excursion Limited all 7.3L Power Stroke Diesels!
tpendergraft is offline
Old 04-14-2006, 09:37 AM   #5 (permalink)
My Photos: (6)
This is a good pump for oil transfer. It is essentially a gear pump using solid vanes or tabs on a shaft. I find flexible impeller pumps dont' take the thicker oils as well. This pump does better but isn't ideal for cold oil (as in wintertime oil collection).
Hatchetman is right about the particulates. I didn't have an intake screen on mine and it sucked up some crumbs and such way inside the pump. End result: broken plastic rigid vane inside the pump. Fortunately, Northern keeps rebuild kits in stock though not in the catalog.
Todd
ToddT is offline
Old 04-15-2006, 08:35 AM   #6 (permalink)
I bought a this http://www.northerntool.com/webapp/w...t_6970_508_508
Pretty much the same pump just with the hoses.
It doesn't work for winter collection. You will need a screen for the pickup and it gets clogged with particals pretty easily, then your banging it on the side or whatever and oil is flyin everwhere. It'll pump 50gal in about 5 min (hot). But, beware that it has a 20min duty cycle and if your pullin thicker oil it gets hot(the motor) really quick. Oh, I almost forgot, it's really loud!
I use it for transfering oil in the garage not for collection.
MasterTrim is offline
Old 04-15-2006, 09:34 PM   #7 (permalink)
This one is a little pricey, but its a really good one. I have the AC version and have had NO problems at all.
RoReRi
New to me... not anymore...
02' 4x4 | F250 | CC | SB | Auto | 3.73 rear end
Running boards | Tow Mirrors | Tymar intake | DP-Tuner 80hp Eco, Stock, 60hp Tow | Fumoto drain | Sony,CDX-GT610UI | 2.5" TuffCountry leveling kit | 4" MBRP exhaust, turbo back..
96' 4x4 F250 EC 4"lift Ranch Hand Front and Rear bumpers. Tymar intake and downpipe & Cat delete pipe. 203 degree T-stat, $40 AIC, Stage 1 INJECTORS...
Running WVO since May '04
Be without fear in the face of your enemies
Be brave and upright that God may love thee
Speak the truth even if it leads to your death
Safeguard the helpless
THAT IS YOUR OATH
roreri is offline
Old 04-16-2006, 02:31 AM   #8 (permalink)
Spencnaz's Avatar
My Photos: (14)
I used one of those, didn't do squat and the oil was warm, all it did was drain the battery it was hooked to.
I just use a hand crank barrel pump for oil measure and transfer. The restaurant where I pick up oil puts it in the 5 gallon cubies for me, and I do a pickup once a week, preferable during the weekends.
Spencnaz is offline
Old 04-18-2006, 09:59 PM   #9 (permalink)
Wirenut did you get your pump yet? Trying to find out how you like it.
Old 04-19-2006, 12:36 AM   #10 (permalink)
the redline is a workhorse. I am pleased.
2000 F-250 Super Cab Longbed
Bright red, they call me "Clifford"
scottefontay is offline
