Re: 1st batch what did I do wrong?
Well, again we need some more data and your measurements are a BIG part of the problem. Was it new or used oil? If the oil is used, you need to do a "titration" to determine the amount of NaOH to ADD to the base amount. And, the base amount is normally 5 grams.
Measurements need to be precise or you get results like you did...probably an incomplete reaction from the sound of it. You should have 80-95% biod and the rest glycerin/methanol mix if the reaction was complete.
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
