20,000 mile update on my 05 PSD - Diesel Forum - TheDieselStop.com
Old 06-20-2006, 06:10 AM   #1 (permalink)
Since I’ve installed the Plant Drive 6.0 PSD kit here are my results after 20,000 WVO miles.
I’ve gone through 3 of the Secondary filters that are part of the stock fuel system. I’ve gone through 5 Vormax filters. Although these are lasting me far longer now then they were in the early days of my conversion. I guess I prep my oil better now since I can get well over 6,000 miles out of the filters now. I currently use Baldwin BF1212 filters in the summer.
I’ve gone through 2 A1000 fuel pumps. One, about a month after I converted. It died trying to suck oil through a plugged filter. I moved my Vormax vacuum gage into the truck and I don’t have that issue any more. The last one went out suddenly as I was driving home about 4,000 miles ago. I’m going to try the Mallory pump next time this happens. I suspect it will happen again.
The truck it’s self has always thrown the CEL after about 300 miles. The code it throws is PO460 Fuel Level Sensor Circuit. That is because the fuel level does not go down as expected as the miles on the odometer go up. Annoying but easy to deal with, with the ODB II reader/clearer I have.
More recently I’ve started to get EGR related codes PO404 and PO1335. I can clear these and they come back after about 500 miles. I’ll ask the dealer about them at my next service. Not sure if this is WVO related or just one of the many issue with the 6.0 that is starting to make themselves apparent. I read lots of post about trucks that run nothing but #2 and they get these same codes. So for now I’m not too worried.
Over all I’ve been able to get twice as much mileage out of each tank of diesel then I did when I first started. I get any were from 1300-1600 miles between fillups. I commute to and from work 62 miles round trip. A few long weekend trips never tow or haul anything near the trucks capacity. The details of my fuel usage are on my web site.
The Plant Drive kit it’s self has worked great. All of the components supplied with the kit are still functioning the same way they were on day one.
B & E
2005 F250 PSD
Plant Drive Two tank WVO system.
Hotstk, Vormax, A1000, and Vegtherm
Converted at 3900 miles now have 32945
BandE is offline
Old 12-22-2006, 11:32 AM   #2 (permalink)
Re: 20,000 mile update on my 05 PSD
Well another 10,000 miles have gone by. Happily nothing eventful to report.
Entire system working as advertised. Filter life it great and I'm looking forward to the next 10,000 miles.
B & E
2005 F250 PSD
BandE is offline
Old 12-22-2006, 10:51 PM   #3 (permalink)
My Photos: (6)
how big is your tank? i cant find any links to your website
2005 YELLOW Ford F-350 Lifted 35 inch Mickey Thompsons Arp Head studs, Buswhacker Flares, Four Real Steel Light Bar, 4 Piaa 525 series fog lights, K&N Air Filter Kit, Cowl induction hood by Reflexxion, Solid billet grille $$... Sct Xcal3 w/ Xtreme Tunes, T409 cat back mbrp exhuast from Innovative. Amp research electric power steps with led light kit
All running on 100% Home-made Biodiesel! .70 a gallon! If interested in biodiesel drop me a pm.
Brentsbg is offline
Old 12-23-2006, 09:30 AM   #4 (permalink)
Pretty small 15 gallon one I got at Summit Racing. I have to fill it every other day. The last time I made a trip to NC I had to bring 10 cubies of oil with me. I get about 180 or so out of the tank since my pickup is about 1 inch off the bottom. This worked out to be about the same size as my bladder. [img]/ubbthreads/images/graemlins/smile.gif[/img]
www.leskwvo.com but I don't do installs any longer
B & E
2005 F250 PSD
BandE is offline
Old 12-24-2006, 04:38 PM   #5 (permalink)
Ive got over 30k miles on my 06 using a methanol transesterfication and replaced filter once because I thought I should. I think mixing is the way to go. It takes more work...
People like you will hopefully make a solid foundation for others to use later [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2006 F250 4x2, MBPR Exhaust, Factory 20s" w/ 34.2 inch tall tires and 4.10 gear
racing4funn is offline
