55 gal. filter station - Diesel Forum - TheDieselStop.com
Old 08-27-2007, 06:45 PM   #1 (permalink)
I have available , a 55 gallon barrel that is still sealed with a small amount of highway paint at the bottom . I plan to use it for a filter barrel for processing WVO and wonder if I will have any problems with any residual paint that may not be removed with thinner and rags .
93 F250 Super Cab 4x4 E4od 231,000 mi
Tommc56 is offline
Old 08-27-2007, 07:20 PM   #2 (permalink)
Send a message via AIM to VD350
Re: 55 gal. filter station
Wash it out with water and add a gallon or two of gas and splash it all over, roll it, flip it, then drain it. Do that 3 or so times and it will be all gone. Thats how we get rid of oil, paint, and anything else in barrels we plan to use
1986 F-250: 6.9L XL 4x4, 4.10 rear, 4 speed, Wellman GPs, 127,000 and chuggin along like new
1985 Mercedes 300SD: Daily Driver, straight piped
www.Fordemblem.com
My Truck and My Yamaha Tri-Z
VD350 is offline
Old 08-28-2007, 11:19 AM   #3 (permalink)
hheynow's Avatar
If I were you I'd get another drum. Paint residue is nasty to remove especially in a sealed drum. IMO you'll never get it clean enough. Try pouring in some B100 and let it soften up the paint. My 55 gal drums are from a virgin olive oil producer so they come to me empty and clean as a whistle.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 09-04-2007, 10:43 AM   #4 (permalink)
Thanks hheynow , I've recently acquired 4 plastic drums that a pipeline contractor was using for floats in swampy terrain that were used for shipping some sort of beverage product . They should serve well for filtering and storage . I'll be ordering a pump and polishing filter soon !!
Tom
Tommc56 is offline
Old 09-04-2007, 01:16 PM   #5 (permalink)
botman's Avatar
I have been making biodiesel for about a year and have discovered that you do NOT want to risk your injectors of fuel filter on stuff you can avoid. I use plastic 55 gal drums, I like the white ones because you can see what settles to the bottom and avoid it. I would make your drum into a burn barrel and start over. Look around make some calls for the plastic drums, I have never paid more that $5.00 for one and most I got for free. Don't risk a $2k repair for a paint filled drum.
2002 F-250 Diesel, Superduty, Crew Cab, Short Bed, 4X4 Off Road. BFGoodrich 285/75X16 Mudders and a 4" MBRP SS Turbo back exhaust. Upgraded the fog lights so they work with the High Beams. 12/23/04 K&N Air Filter. 01/29/05 New Red Top Optimas. 04/11/05 Bilstein Shocks. Fiberglass Cap. 08/01/05 ARB Sahara Bumper. Warn 16.5TI Winch. 10/20/06 Prodigy Brake Controler. 8/21/07 DP Tuner Stock, 60hp tow, 80hp Econo, 120hp Race.
botman is offline
Old 09-04-2007, 05:34 PM   #6 (permalink)
firemediceric's Avatar
Car washes are usually a good source, but the drums are often blue in color
1999 7.3 F-350 and 2004 6.0 Excursion
Truck: Tymar type intake, Zoo Dad, muffler delete, By-pass coolant filter, Dahl 100 fuel filter Harpoon & Hutch mod, upgrade to 3/8" fuel line and HP oil X-over, Oil by-pass, Scan gauge II.
Excursion: All stock, so far.
firemediceric is offline
Old 09-04-2007, 06:29 PM   #7 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: botman</div><div class="ubbcode-body">I have been making biodiesel for about a year </div></div>
You have been mixing Secret Diesel for a year. Bio Diesel is very well defined by the EPA. Look it up, it contains none of the crap you like. No chemicals, no petroleum products, and most important no snake oil.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 09-04-2007, 06:44 PM   #8 (permalink)
Thanks for the tip on car washes . Mine are blue , but I was told that they originally contained a food product . The 4 that I have should serve my immediate needs . Now I just need to start filling the remaining 3 with filtered oil !
Tom
Tommc56 is offline
