The more I know about biodiesel,
the less I know about biodiesel.
"You have reached Mr Medic. Please leave a message after the beep. If you would like to hear this recording in a language other than English, take your ass to a country speaks it"
I have several black ones. If you have a way to get it from Nebraska, you can have one. I do have a former neighbor who trucks in that direction, how flexible are you as far as meeting him somewhere to pick it up if I can get him to bring it to Houston? I am sure he would, I just do not know how often he gets to Houston.
Norman
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
MrMedic, went by Steinhauser's today to get feed, they are 16.50 but didn't have any today. Galco Hardware off 6 in Santa Fe has them and a place off 146 near Kemah also has them.
MrMedic, if you are interested I have a 55 poly, but I cut the bottom out of it. I had it inverted with screen in the hole I cut in the bottom to filter my oil. It was my filter and settling drum. I now use a 300 gallon tote with panty hose, but you are more than welcome to the poly. I'm only 5 minutes from Steinhauser's if you head that way.
MrMedic, what part of town are you in, I know a place near conroe that i get'em from that has a couple of different sizes of the poly, they are previously used, so they are inexpensive...
2000 F-250 crew cab 4X4, Turbonetics BB, Ford AIS w/fender sleeve mod, hypertech, 4" exhaust, ITP Overboost Annihilator, Banks Big Head, Veggiestroke Cackle Cure, HP Oil Xover, CCV Mod, 6.0 Tranny Cooler, 6.0 Intercooler, green to Red Fleetrite coolant, 203* thermostat, Coolant filter, Stancor GPR mod, TurboLifeSaver, Mag-HyTech Rear End cover, heater core shut-off
You guys that are looking for drums should check with your local carwashes. I've been able to get all I want for free. All their soaps, cleansers and waxes come in them and they come in 15,30 and 55 gallon sizes. And they're all translucent so you can see the oil level or progress as the oil settles.
Zooman: I think for the washer I'm building with it, I'll need most of the top on, but thanks.
txfdcapt: I'm in west Houston, I-10 and hwy 6. But if the carwash idea doesn't work out, I'll check with you about your source. P.S. Supervisor 69A here. Are you HFD?
Blue Mule: Thanks, I'll check out the car washes near me today and see what may be available.
Thanks to all, as usual, there are always new ideas out there.
I have about 50 every year that we turn into trash cans. I work at a marina and all of our non toxic antifreeze comes in these 55 gallon drums. I'm not sure if boats get winterized in Houston, heck I'm not even sure if theres water in Houston [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img] but that would be another option. Good Luck
Frank
__________________ http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
Go to any of the better car washes; they have BUNCHES of them! Just wash em out good with the clear water rinse at your local car wash. Usually only $2.00 - $4.00 each for either 30 or 55 gal.
1992 2WD F-250 SuperCab 7.3L 5-spd 4.10 rear. Changed to 5w-40 Rotella Synthetic oil in the crankcase & Deep Purple Synthetic ATF in the Trans. 38K on new Jasper longblock, Bought truck from local University (MSU - 09/20/06). Replaced O-rings on return line caps with Viton. Now on to tackling Biodiesel!!
