I don't have a 6.0, but now that most of them are out of warranty, a lot more people are running them on biodesel, so I'm interested in the subject.
It REALLY seems to me that people have trouble with these on 100% biodiesel. They seem to develop this weird goo after some number of miles (sometimes 20,000 miles, sometimes less, it seems to be unpredictable how long it takes) that comes out of no where and seems to just keep on coming.
What seems to happen is that something disintegrates in the fuel system, and destroys (extremely expensive) injectors. It doesn't seem to be related to fuel quality as far as I can tell. It seems to be related to using a biodiesel/diesel blend over 75%.
Also, the goo is not caused by petroleum residue in the tank being cleaned out by biodiesel, as it happens to very new vehicles with no history of residue (and this doens't happen to any other vehicle that I know of).
Usually 6.0 drivers seem to have no problems at B50 (50% biodiesel, 50% diesel). I think I've heard pretty consistently that B70 or so is fine as well.
I have heard a rumor that it was finally tracked to the stock filter, and that the element dissolves in 100% biodiesel. I'd like to know if there is an aftermarket replacement for the stock filter or if anyone knows for sure that the original filter is the cause of this problem (anyone want to send me an old stock 6.0 filter that I can soak-test in biodiesel- I don't feel like going out to buy one just for this test).
There was a lot of misinformation about what caused this when the 6.0's first came out and people started seeing this problem for the first time.
At first people thought the goo problem was due to the fuel being destroyed by the high pressure fuel system, so this led to a persistent rumor that all common rail injection systems would have problems on biodiesel. This has been completely disproven.
You might still run into someone on the net saying that it's fuel 'polymerization' due to high pressure. However, no other vehicles with a high-pressure fuel system seems to experience this issue.
I have heard a couple of times now that it's the fuel filter in the 6.0, and I'm trying to track down whether anyone knows for sure that this is the case.
I haven't been able to find positive confirmation that changing from the stock filter to an aftermarket filter gets rid of the problem permanently. The clogging goo problem may recur 20,000 miles later (I've heard from couple of users that this happened to) or may recur sooner, so it's hard to tell whether a change has helped or not unless you follow a user's experience for a long time.
Also, I don't think the same set of problems happen on SVO or solvent blending with these trucks.
Homebrew biodiesel crazy:
...several years with a couple of different 6.9's... now running a (gasp!)1998 GMC 6.5 van... don't shoot me.
Reason: hit 'send' before finished typing title!
So after reading this I went out and checked my used filters. They are still soaked with b100. They were used for around 5000 miles and 2 1/2 months. I then checked the new unused filters that I keep for future changes. The glue that hold the filter to the plastic is probably what you are talking about. After comparing the new and used they seem to be about the same soft consistency. Maybe if the filter was in service longer it might degrade. I have been using b100 since April and just started mixing to b75 and soon to b50. I have a little over 20k since I started using biodiesel. I have never had that gue problem but I also change my filters around every 5k miles. So my thought is that maybe the gue problem would be from not changing the filters often enough. But I would like to know more about this gue problem.
2005 F350 6.0 PSD srw lb sc Zf6 speed
mods: BD exhaust brake- Dura flap mud flaps-Piaa back up lights-Wilson cell amp and antenna-Midwest short throw shifter--C-Betr mirrors-Burning B100
The weird thing is that if it's a filter problem, you'd think that drivers of new trucks, that were still under warranty and were getting regular service, wouldn't have problems. I've informally tracked the mileage on these stories and some of them are 20,000 miles apart. Maybe that just means that once in a while a filter fails, and most of them don't- so even though a 20,000 mile user was fine through 4 filter changes the 5th one gave out and caused the problem. The other issue is that sometimes the problem recurs at very short intervals- so if it's a filter issue, there could be an explanation along the lines of 'it was a whole lot of bad filters that their dealer stocked' or something like that. It still doesn't quite make sense to me.
I guess I'll have to go track down one or two people who've actually had this problem in person and try to get more info.
Do these trucks have lined tanks?
I am not sure if the tanks are lined. My tank is made of plastic so I wouldn't think it was lined. Maybe there could be some fuel line that is degrading. It makes more sense to me that it is a fuel problem. Maybe alge growth from using biodiesel long term?
I Am On My Third.the First Was Not Ran On Bio, Because It Was In The Ford Garage More Than Mine. I Ran 35,000 Miles On My 05 B100 Every Mile. I Have 10123.00 Miles On My 06 6.0. I Have Only Ran One Tank Of Diesel. I Have A 60 Gal. In The Bed. I Have Three Others Who Run B100 In A 6.0. I Think Ford Recommends 10% In The 6.0. We Make Our Own Bio-diesel. I Just Don't Think This Is A Filter Problem.
I was running B100 in my truck. I only put the Bio in the Aux tank, and let it fill up the main tank. I knew that the Bio would clean out the system after the first couple of tanks, so I replaced the filters after 500 miles; they were pretty dirty looking!
I have a small filter between the aux tank and the main tank. After about 10k miles, the small filter clogged up and I needed the fuel from the aux, so I removed the filter.
About 150 miles later, the stock filters completely clogged! The truck wouldn't go over 35 MPH. I replaced the filters (AND the small filter for the aux tank) and everything worked fine again.
I buy the Bio from a large truck-stop fuel dealer near me. He moves large amounts of the BIo, and has all the regular filters at the pumps.
So, I think the problem has to do with filtering.
I don't think that any of the major Bio producers filter to a small enough micron level. I think this causes the 6.0's filters to clog up.
The little aux tank filter that I used was just enough to filter out the goo from the bio.
I LOVE running Bio Diesel, but I've had to cut back to B20 because of the clogged fuel filter problems.
SInce switching, I still see the aux tank filter cogging up, but it seems to last a lot longer.
I think the guys that make it themselves filter the Bio a lot better, so they never have any issue.
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/ custom tunes from Innovative
ARP studs installed
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
Upfitters w/ high-idle mod
40 gal aux fuel tank
running B80 to B100
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Bed cover
I have been running B100 in my '05 6.0 since it had 5,000 miles on the clock. It now has 37,500 miles on it. I have not had any issues whatsoever. The last time I changed the fuel filter there was some black crud in it. I think that came from the one tank of petro diesel I had to buy to get me home once becasue I had neglected to fill up before I left.
2005 F-350 XLT 4x4 SRW Reg Cab long bed 6.0PS tow command
1986 F-250 4x4 woods truck - well broke in 460 gas, they can hear the sucking sound all the way to Texas!
1989 F-250 XLT 4x4 SRW 7.3 IDI soon to replace the '86
Check these bio compatible filters. Then maybe filter with a centrifuge. They filter down to .5 micron. Better than any other filtering and a lot less messy I would think.
03' F350, 6.0, Crew Cab, Six inch lift, Amp Power Steps, Jimmie Jammers. Looking for help and advise to safely upgrade.
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. New custom tranny on the way to get me sub 4 sec. 0-60, top speed of 215mph and about 40mpg all at the same time!
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, over 750 functions. Still don't know them all yet. For Sale! Buyin' a diesel car.
Just did the oil, fuel, tranny filter change thing.
The fuel filters were very clean. I probably did not really need to change them. 38,000 miles with 32,000+ on B100.
