7.3l idi return o-rings - Diesel Forum - TheDieselStop.com
Old 01-05-2008, 09:43 AM   #1 (permalink)
Does anyone know were I can find the correct return o-ring to run on my 7.3idi?
thinking of converting to wvo and want to make sure I have no problems. I have heard that the o-rings and return hose can be an issue for leaks, and want to take care of it all before I do the project...
thanks much in advance
diesel67 is offline
Old 01-05-2008, 12:05 PM   #2 (permalink)
Re: 7.3l idi return o-rings
napa auto parts or any auto parts store sells a kit i think for $50. With everything you need hosses, clamps, and o-rings.
92 F-250 with luk clutch, got 304,000 miles out of old motor, now have IDI out of a 94 With factory turbo. Bought and installed ATS Exhuast housing, wastegate, downpipe. Turned up pump electric fuel pump. Runs like a bat out of hell.
andre7910 is offline
Old 01-06-2008, 08:52 AM   #3 (permalink)
thanks andre, I will look in to that.....
diesel67 is offline
Old 01-06-2008, 10:25 PM   #4 (permalink)
Get them from http://www.mcmaster.com (mcmaster-carr). VITON o-ring in the EXACT size that you need for the return caps. Mcmaster part No. 9464K24 just put that in the search box. You get a bag of
-50- of them for only $5.93 !!
They also have the viton return line in the right size too. Sell it by the foot. mcmaster also has the fastest shipping on the planet, I swear!
Make sure you Vaseline the 0-rings good before you try and put them on, and for whatever reason, you put the top one on first, then slip the 2nd one over that; just works; dunno why!
1992 2WD F-250 SuperCab 7.3L 5-spd 4.10 rear. Changed to 5w-40 Rotella Synthetic oil in the crankcase & Deep Purple Synthetic ATF in the Trans. 38K on new Jasper longblock, Bought truck from local University (MSU - 09/20/06). Replaced O-rings on return line caps with Viton. Now on to tackling Biodiesel!!
kleenax is offline
Old 01-09-2008, 09:07 AM   #5 (permalink)
kleenex, thanks.. .do you happen to have the number for the return hose?
diesel67 is offline
Old 01-10-2008, 11:26 PM   #6 (permalink)
You should be ok, should be. Then again the this issue did just throw me for a big loop. The only leads I have on the condition of the return loop is, if your showing diesel seepage under the injectors collecting in the valleys where the glow plugs sit. I was sure mine were blown when I failed to pull a vacume on one side when I could do it well on the other.
Try here if your interested,
http://shop.dieselpage.com/category.sc?categoryId=29
I have to admit though the McMaster's route might be a good one if you still trust thoes funny little boots are good. Just be sure not to use worm drive hose clamps, only spring clamps and screw type (injector) clamps.
WilsonJ is offline
Old 01-15-2008, 09:03 AM   #7 (permalink)
thanks for the info Wilson
diesel67 is offline
Old 01-28-2008, 06:48 PM   #8 (permalink)
Cucamongan's Avatar
I search McMaster for the Viton hose, but it threw me through a loop by having to scroll down the left side bar to "Viton Tubbing"
So I will share what I found
Here are the Part #'s
*** These are all for my '88 7.3L IDI Diesel Engine***
FIRM Black Viton Hose for the hoses between injectors: 5119K13 = $5.02 per foot (1/'08)
(also available in Green and Brown: 5119K861 = Green., 5119K864 = Brown)
SOFT Black Viton Hose for the hoses between injectors: 5119K43 = $5.61 per foot (1/'08)
5 Feet should be enough
FIRM Black Viton Hose for the hoses from the fuel tank to fuel pump & to the return line on the back of the engine: 5119K21 = $15.26 per foot (1/'08), {5119K891 = Green. 5119K894 = Brown)
SOFT Black Viton Hose for the hoses from the fuel tank to fuel pump & to the return line on the back of the engine: 5119K51 = $14.79 per foot (1/'08)
3 Feet should do.
I'm Doing all these hose replacement as precautions before running BioDiesel...
My Truck: '88 Ford F-250 No Frills Standard Cab, ZF5, 7.3L IDI Diesel, No turbo (Needs one!)150K miles ( 250?) One Tire Fryer open Diff., 2wd. Shes been used and abused and I'm trying to give her the loving she needs.
Cucamongan is offline
Old 01-29-2008, 10:03 PM   #9 (permalink)
Cucamongan's Avatar
I 2nd That!
I ordered Yesterday afternoon and they came today, afternoon
Old 10-14-2009, 08:32 PM   #10 (permalink)
Sorry to dig up an old post, but - do you recommend the "firm" or "soft" hose? I would think the soft, but wanted to check...
Thanks,
Chris.
3 Feet should do.
ctann is offline
Old 10-14-2009, 09:17 PM   #11 (permalink)
Make sure you give them the model year of your truck- the hose diameter changed in 1989 MY.
Evel486 is offline
Old 10-14-2009, 11:49 PM   #12 (permalink)
Oh yes, mine is a 1990 F250 7.3l IDI. Thanks for the tip, I'll double check the diameter requirements too...
Chris
ctann is offline
