93 7.3 idi turbo conversion
I am converting to wvo and would like to find someone to share in detail their system so I can do it right the first time. I am going to use a racor 500 filter for wvo and stock for diesel, HOH for the fuel line, twin electric pumps(getting rid of mechanical pump) 3 way valve after stock filter and 3 way for return line that recirculates wvo through the IP and diesel back to tank. I am probably going to use a heater core to heat the tank. Questions are, which coolant line do I break into, the one coming off the passenger side of the block that tees into the radiator or the one that comes off the water pump and should I need an aux water pump for better flow back to the tank. Next, can I just remove the return line to the filter so fuel doesn't go back there and just tee it to the rest of the return lines. And lastly I have heard of people using glow plugs in fuel lines for heating, has anyone used one in the racor turbine series filters. There is a port hext to the fuel outlet that could have one with the aid of a reducer screwed in. Would a relay need to be used or can it run continuously. I think that is all the questions for now... I stress for now. thanks for the help.
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
2006 Dodge 2500 Megacab Cummins...stock...for now..hehehe
