Re: Acidic Isopropyl in titration?
I used the ph meter at work and when I added the isopropyl it went crazy? Jumped up to 12 the down 7 I finally gave up and will have to do something else?
Not sure about this isopropyl alcohol used with pH meter. In order to use pH meter, isopropyl alcohol isn't needed at all. Just need 0.1% NaOH solution. Add the NaOH solution to the oil sample, until the pH meter shows 7.0. Count how many mL of NaOH solution added to the sample.
Of course, 1 mL of oil in titration isn't enough for the pH meter to measure. So scale up alittle bit might be nut way to go.
I never try pH meter myself. I think that it is good idea to measure the isopropyl alcohol first. Then add 0.1% NaOH solution until pH meter hit 7.0. It should be stay that way. Just basic blank titration. If pH meter goes crazy, maybe it isn't good meter for titration. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Bluenavigator
'95 F-350 XLT PSD, CC, 2WD, Garrett Turbo AR 1.1, 5spd ZF tranny, LUK, 4.10 Limited Slip, just added Dual Arm Tenisoner. Just added my ol' vacuum gauge to monitor my vacuum pump.
