Adding other oils to veggie - Diesel Forum - TheDieselStop.com
Old 07-23-2004, 11:22 AM   #1 (permalink)
My Photos: (6)
I read here or on another veggie forum about adding some mineral spirits to the used veggie oil. Others have talked about adding used tranny fluid and other oils of similar viscosity.
I'm kind of chicken about the mineral spirits for safety reasons as most mineral spirits have a 108 degree flashpoint. Diesel is usually up in the 175 to 180 degree range if I'm remembering correctly.
But, what about other solvents? I have a few drums of a high flash solvent (non halogenated) that might be a good additive to keep things cleaned out. I'm only thinking of adding a couple percent to the veggie. I know it has a good BTU and is a little thinner viscosity than regular diesel. I used to mix it with a another solvent similar to #1 diesel for a cleaning chemical I manufactured. After we used it to dissolve cosmoline off of new mild steel, we disposed of it as a waste fuel for burning in a boiler. They liked it because it helped dilute the Bunker C oil.
I will be installing a heated veggie tank and switching between dino and veggie. I will also have plenty of filtration in my system.
Todd T
I don't know enough about the combustion requirements of the PSD to try it without hearing from some folks who know a lot more about fuel than me.
ToddT is offline
Old 07-23-2004, 11:43 AM   #2 (permalink)
Re: Adding other oils to veggie
DO NOT mix motor oils or tranny fluids or hydralic fluids in with your fuel.
While Ford may be wishy-washy about Bio-D, they are ADAMANT that you not run Engine oil or tranny oils or the like thru your motor.
Those other oils have detergents and additives that do not burn correctly, and can add deposits to your engine that will destroy it down the road.
Stick to diesel fuel, Bio-D, or heated veggie. At least you know that stuff is safe.
Ford_Forgotton is offline
