Algae x - Diesel Forum - TheDieselStop.com
Old 09-29-2007, 12:32 AM   #1 (permalink)
ajohansson's Avatar
Algae x
Anybody ever used the Algae-X? Lost of user recommendations on the website. Maybe worth a shot. http://www.algae-x.net/
ajohansson is online now
Old 09-29-2007, 05:56 AM   #2 (permalink)
Re: Algae x
They don't seem to mention it for biodiesel... I've certainly used diesel fuel that was way older than 90 days with no ill results.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 10-03-2007, 12:40 PM   #3 (permalink)
Re: Algae x
Eric,
Which of the Algae-X products did you use and where did you purchase it?
Thanks! Stu
1999.5 E-350 XLT Extended 12 Passenger Wagon 7.3PSD. 100% stock except for dual K&Ns, but looking to change that...
Late99EconoWagon73 is offline
Old 10-03-2007, 12:46 PM   #4 (permalink)
hheynow's Avatar
Re: Algae x
I use Killem and it is rated for oils (WVO & bioD).
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 10-03-2007, 06:49 PM   #5 (permalink)
Re: Algae x
Killem is highly recommended and available at UBS
97 F250 CC PS Tymar intake, 3" downpipe, 4" exhaust, turbo muffler installed backwards, 299,000 miles, running B100 when possible. "NEW 90 F450
StorminNorman is offline
Old 10-04-2007, 10:18 PM   #6 (permalink)
hheynow's Avatar
Re: Algae x
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: StorminNorman</div><div class="ubbcode-body">Killem is highly recommended and available at UBS
</div></div>
Cheaper HERE
hheynow is offline
Old 10-09-2007, 12:50 PM   #7 (permalink)
Re: Algae x
Found the Killem at a local truck parts store for $14.00 + tax.
The Parts Guy suggested wearing the HazMat suit when using it. Must be good stuff.
Haven't read directions yet to determine how much to add per gallon. Any recommendations?
Thanks! Stu
