anyone here of this www.dieselsecret.com CO? - Diesel Forum - TheDieselStop.com
Old 12-14-2005, 01:41 PM   #1 (permalink)
Send a message via Yahoo to mlohaus Send a message via Skype™ to mlohaus
I'm about to pick up my second Diesel and I'm wondering if this stuff will work or if its bunk. www.dieselsecret.com I have a 01 PSD that I'm trying to get some HP out of but I may consider a conversion to Bio if it does not hurt HP and preformance since I'm building a go fast truck. I do however have a commuter and since its Germain it's already approved for a B10 and soon to be B20 ratio. Let me know if this stuff works at all and is all its cracked up to be. I live in a cold climate so I probably won't operate more than a B50 rating in winter but in the spring, summer and fall I may look into B100. I'm not intrested in getting into chemistry now so I thought this may be a close alternative. If fule hit $3 again I may re-think becasue then my fule bill starts to look like a mortgage payment. Thanks
01 F350 CC SB 4X4
Slightly Modified
Powered by Oil driven my Madness
577 HP 951 Trk
mlohaus is offline
Old 12-14-2005, 01:55 PM   #2 (permalink)
Re: anyone here of this www.dieselsecret.com CO?
Do a search on this in this forum. There is not enough data on this stuff as to what it does to your engine long term. You mix Kero, Gasonline, Cetaine boost, and thier "secret" together, run through 3 filters, one being a water filter. Basicly you are making a 75/25 blend. You can do this without thier secret stuff, and without paying 40 bucks for it. I am running a 75/25 blend of WVO/#2 in my truck right now. Depends on your climate, it stays warm here, I dont use a heater on my tank. In most peoples opinion, it is snake oil and not a good thing for your ride.......
Kennyray
1990 F250 4x4,3.55, E4OD, LWB,Supercab, 7.3 XLT Lariat HD. Alum steps, Red/Tan, Red interior, Captains Chairs, Sirius Satellite Radio. 16X8 Alum Wheels. Alum. Tool Boxes all the way around. 215,000 Miles and climbing.
BOOB man in Alabama. WVO experimintation in progress.
kennyrayonline is offline
Old 12-14-2005, 02:41 PM   #3 (permalink)
That's what I figured. What is WVO. Thanks
01 F350 CC SB 4X4
Slightly Modified
577 HP 951 Trk
mlohaus is offline
Old 12-14-2005, 03:00 PM   #4 (permalink)
WVO = Waste vegetable oil (dirty from the fryer).
--Hugh
p.s. Diesel Secret is NO secret around here [img]/ubbthreads/images/graemlins/vomit.gif[/img]
1991 F250 XLT, 2WD, 7.3L IDI, 5 speed, 168K.
waterdude is offline
Old 12-14-2005, 03:29 PM   #5 (permalink)
I'm assuming that you filter it to remove particulate materials. Would it also make since to chill the oil to help remove some of the fatty solids. To be honest that last time I ran b10 I belw my HPOP off the side of my engine. It was like -15 with wind chill and I've stayed away since. May re-think if I can find/make it cheaper without having to store a bunch of stuff.
01 F350 CC SB 4X4
Slightly Modified
577 HP 951 Trk
mlohaus is offline
Old 12-14-2005, 08:42 PM   #6 (permalink)
bluenavigator's Avatar
My Photos: (5)
75/25 Blend and B10 are not same thing. 75/25 Blend means 75% diesel mixed with 25% WVO (of course, filtered to remove unwanted debris/crud). B10 is 90% diesel mixed with 10% biodiesel.
In fact, biodiesel is better for engines than diesel due its better luberiation properties. Sorry about HPOP that it blew up, it is subjective to happen. Biodiesel have nothing to do with HPOP.
Bluenavigator
'95 F-350 XLT PSD, CC, 2WD, Garrett Turbo AR 1.1, 5spd ZF tranny, LUK, 4.10 Limited Slip, just added Dual Arm Tenisoner. Just added my ol' vacuum gauge to monitor my vacuum pump.
bluenavigator is offline
Old 12-18-2005, 12:17 AM   #7 (permalink)
I know it was just a cold day and it ticked me off I figure the pressure regulator got stuck closed and thus critical mass was reached. I've heard of many folks having issues and seeing something like 50K psi in the HPOP becasue of issues. As of Monady I'll have a new toy to put bio in and since it from Germany it rated to b10 in the states and b50 in Europe. I may look into some higher ratings but it's damn cold this year.
01 F350 CC SB 4X4
Slightly Modified
577 HP 951 Trk
mlohaus is offline
