Anyone using propane to increase mileage? - Diesel Forum - TheDieselStop.com
Old 08-21-2008, 03:36 AM   #1 (permalink)
VegasDiesel's Avatar
I just went through my Diesel Power Mag and it covered the Diesel Power Competition. There was a guy getting 38mpg on his truck with propane. Anyone know where I can learn more about getting a system like this or more information on it? Anyone here using it? Opinions? Thanks guys.
03' F350, 6.0, Crew Cab, 4" lift,
Amp Power Steps,
Jimmie Jammers.
4" Turbo Back MBRP exhaust,
Adrenaline HPOP from Dieselsite.com.
155 injectors, egr fix, ARP studs, black onyx gaskets, and SCT custom tunes. All from River City Diesel!
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. been down for a long time and finally getting my tranny rebuilt to handle the power...I hope.
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, yadda yadda. Always in the shop.
Yes the girl in my avatar is actually "my girl"
VegasDiesel is offline
Old 08-21-2008, 04:51 AM   #2 (permalink)
Greasy_Dually's Avatar
rpmoutlet has the motoblue kit. It uses coolant to heat the propane, just to make sure it doesn't get into you truck while still liquid. Keep in mind you will be substituting diesel for propane, so your MPG calculations should take into consideration how many gallons of LP you use. That being said propane is currently cheaper than diesel!
The propane also acts as a catalyst so there is some increase in efficiency, meaning your MPG when accounting for both the propane and diesel used will be a little better than running diesel alone.
97 7.3 CC 2wd Dually 140,000 mi. stock except for
DIY Intake
Transmission Just Rebuilt, Tugger Kit, Billet Converter, Steel Gear Sets, Larger Cooler
Greasy_Dually is offline
Old 08-22-2008, 08:49 PM   #3 (permalink)
The diesel power mag with 38mpg, isn't that with CNG - natural gas
2002 F250 CREW CAB 4X4 7.3L
DannyCAD is offline
Old 08-23-2008, 02:28 AM   #4 (permalink)
You know what, it was the truck with CNG. Anyone doing this? More info on it?
Amp Power Steps,
Jimmie Jammers.
Old 08-23-2008, 03:16 AM   #5 (permalink)
88beast's Avatar
lpg and natural gas burn the same natural gas just needs to be filler at a different place idk where
they will act and preform the same no difference
lpg (propane) will go fast with a small tank but a larger tank will need less refueling so go with a large tank
and go with a professionaly made kit itll be easier in the long run
88 F-250 body,550 rear frame setup, 7.3 idi, back up camera, class 5 bumper hitch welded to frame and gusseted, front mount hitch and off road lights,93 front clip, headache rack, 37" humvee tires, ac power converter,factory buckets from quadcab, power windows and locks,cobra 29 cb w/ 102" whip, high lift jack behind seat, toolbox for the junk, visor, running lights, huge front bumper, oba,
in progress western style mirrors, holset turbo, airhorns, and some other goodies
88beast is offline
Old 08-23-2008, 06:07 PM   #6 (permalink)
I have run the powershot system for quite awhile - actually I have not filled it for some time since the cost per mile does not go down significantly. If I were towing, there might be more of a benefit.
A Rusch is offline
