B-100 and rubber degradation and fuel pump seals in OBS PSDs - Diesel Forum - TheDieselStop.com
Old 04-18-2006, 10:54 PM   #1 (permalink)
hheynow's Avatar
When using B-100 exclusively, the lubrication could degrade certain types of rubber over time, which may require replacement of fuel hoses or fuel pump seals.
For those of you with '94-'97 PSDs running B-100 or WVO (not B-20), have you encountered any problems with fuel leaks due to rubber degradation or fuel pump seal leaks? I've heard that sometime during the 90s they changed the composition of the hoses and seals to those that won't react with B-100.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
Old 04-18-2006, 10:58 PM   #2 (permalink)
brahamfireman's Avatar
Re: B-100 and rubber degradation and fuel pump seals
all last summer I ran Straight WVO, or a mix at least 75% WVO and 25% #2 in my front tank no heat or anything and I never noticed a problem with the rubber hoses. just started again last week.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 04-20-2006, 02:18 AM   #3 (permalink)
Re: B-100 and rubber degradation and fuel pump seals in OBS PSDs
I have 2 = 7.3s the fuel line going to the filter on my 93 was breaking down turning into a tar like substance My 89 no problem. Both trucks had engin changes so the engins might not match the year of the truck . Im puting a new engin in the 93 (Not a biodiesel problem)and I am insisting on Biodiesel compatable parts. I have had to change both injector pumps . They has a sinthetic solinoide in the injector pump that breaks down with B100. The new pumps have a SS solinoide.
Terry
88 E350 , 93 E350 , 99 International , 2 X 84 Benz's and heating my home all with B100
Check out my Air Care score on B100 http://halverson.ca/aircare/aircare.pdf
Terry
terryrret is offline
Old 04-23-2006, 11:09 AM   #4 (permalink)
bnvcrows's Avatar
I would also like to know if my 2003 is ok.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
SLAPS Member
Edge with Attitude & Bush Fender Flairs
Amsoil 3000 5w 30, Amsoil EaAU Air Filter, Amsoil Dual Remote By-pass BMK-16A,At 38,000 miles on oil Had to change I went long enough still was ok to run.
Amsoil ATF Transmission & Transfer case, Amsoil 75w-140 fluid front & rear end , Amsoils Antifreeze, Transmission Magnefine filter, 4" Turbo Back Exhaust
Sportman Tonneau Cover
bnvcrows is offline
Old 04-23-2006, 01:00 PM   #5 (permalink)
From talking to some other WVO users, there seems to be a change over to the "new" type of rubber hoses in the mid 90s. Some say 93 and other say 96.
I would pose that question to some of the vendors here that are doing kits. They usually have done some research and maybe able to give a more authoritative answer.
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Wildman chip, AFE Stage 2, 6.0 IC, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Tranny Shift Kitted, Billet Torque Converter, Tru Cool 4739 w/Thremal Bypass, EGT Shutdown Monitor, Air bags, EGT/Boost/Tranny Piller Guages
warpdriv is offline
Old 04-23-2006, 02:31 PM   #6 (permalink)
I am testing some fuel line by soaking it in B100. Not real scientific but I can sure see the results.
Right now, regular rubber fuel line will go start to degrade in about a week. When you handle it, your fingers turn black.
Parker Haniffin Hose #801 (synethic rubber) is showing no signs of any degradation. Remember, not all hose has the same innner linning as outter, so a fuel line that runs BD through the inside may be fine, but if BD gets on the outside, it may break it down.
I spoke with Parker Haniffin and they will only stand behind B20 on certian hoses. Of which #801 is NOT one.
I am running B100 through the #801 and a short peice of it is used IN SIDE the tank to hold the pickup screen to the pickup tube.
Have not been running it this way for long so no conclusions.
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
